Attaching Bottom Plate To Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 07:25 PM   #1
Rewards Points: 83
Attaching bottom plate to subfloor
Hey folks. I just stumbled on something I haven't thought of yet. I am building a room in my attic. On one wall there is no floor joist under where the wall will be. Do I just nail the bottom plate into the subfloor? Thanks for your time!
bduncan118 is offline   Reply With Quote
Old 02-20-2013, 10:59 PM   #2
Rewards Points: 150
I assume its too late to put blocking between joists to be able to nail bottom plate to
kaschmid3 is offline   Reply With Quote
Old 02-20-2013, 11:02 PM   #3
Rewards Points: 83
Unfortunately yes. The subfloor was already down when I bought the house. Essentially what I'm doing is framing 4 walls on an existing sub floor in a large space.
Old 02-20-2013, 11:10 PM   #4
Rewards Points: 150
Not structural u will be fine if u r worried about moving just put little bit of glue under but not necessary
Old 02-20-2013, 11:25 PM   #5
Registered User
Rewards Points: 5,212
Do the walls tie to the rafters?
Gary
Old 02-20-2013, 11:29 PM   #6
AHH, SPANS!!!
Rewards Points: 1,166
placing any type of wall between joists and onto sub flooring only is asking for a sagged floor under the wall in the future. how tall the wall is and how thick the sub flooring will determine the rate of sag. subflooring can be cut and removed to allow access for blocking and then the subfloor can be put back down
hand drive is offline   Reply With Quote
Old 02-20-2013, 11:52 PM   #7
Rewards Points: 4,534
since the sub-floor's nailed to the floor joists, i wouldn't worry,,, just did a room over the garage which was about the same,,, 4' kneewall & i screw'd the short vert 2x4 studs into the side of the roof trusses,,, finished off great & have no fat friends under 4'' tall so no problemo
use long drywall screws &, if you want overkill, some const adhesive under the plate ( i didn't )
Old 02-21-2013, 07:52 AM   #8
Rewards Points: 3,130
I would use construction screws, not drywall screws.
Old 02-21-2013, 07:59 AM   #9
uncertain what ' construction screws ' are but i use what on the shelf then again, never said i was a carpenter another advantage of being raised on a farm - baling wire & chewing gum now updated to version 2.0 - duck tape
Old 02-21-2013, 08:09 AM   #10
Rewards Points: 13,266
Sheetrock screws are to brittle for framing, infact no scews should be used in any framing, only nails.
Old 02-21-2013, 08:23 AM   #11
just to hold a btm plate ? c'mon, joe - i wanted to finish this part w/o having to run to the nearest apron/vest store,,,,,, scheeeeschhh,there's lateral force on this sole plate,,, IF it makes you feel better, i used lead-shield drop-in's for btm plate on the bsmt exercise room's wall,,, i can see you never had to finish anything w/my bride, nagzilla, hanging over your shoulder
i'm not taking any more abuse today !
Old 02-21-2013, 08:31 AM   #12
AHH, SPANS!!!
at the orange big box store spax has some construction screws made that work like cabinet screws with shear strength. an exterior decking screw will also work sometimes for framing applications but will still snap if sheared... can't beat the good old hand driven nail in certain apps, and even nail guns if you got em...
The Following User Says Thank You to hand drive For This Useful Post:
joecaption (02-21-2013)
Old 02-21-2013, 01:11 PM   #13
Rewards Points: 83
Gary,
The walls do not tie into anything up there. They will be 4 independent walls (with a ceiling of course). The rafters are above where the room will be. The subfloor itself is 3/4" T&G that is glued and nailed. I will be screwing it down before the carpet goes down.
Where u see the bottom plate on the right of this picture is where the wall will be going. It is 3 1/2'' off the exterior wall.
Old 02-21-2013, 09:16 PM   #14
Not A Licensed Pro
I would go with this advice ... and 16D nails which is probably what you used to build the stud wall.
I myself and quite familiar with the bailing wire method we have here down South, grew up in rural areas myself, but if you ever want to sell that house without having to tear out those rooms, I would make sure you do it to code. I think each space in an unfinished basement needs at least 1 electrical outlet, I would research that and to make sure something similar doesn't apply to unfinished rooms in an attic.
kevinb70 is offline   Reply With Quote
Old 02-21-2013, 09:22 PM   #15
Rewards Points: 83
The room is definitely going to be up to code. I pulled permits and it will be inspected. Unfortunately the code doesn't specify this situation. I can put 300+ pounds on the floor and jump and down and the floor is solid.
Rotten bottom plate advice!! Dirtyfrogg General DIY Discussions 4 10-18-2011 08:20 PM
Does anybody use/suggest Ramset pins for attaching base plate to cement? jobblyman Building & Construction 23 10-30-2010 12:39 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
attaching top plate to existing ceiling derek9 Carpentry 5 07-30-2009 08:14 PM
