Old 03-29-2010, 12:02 PM   #1
Attaching Blocks to Concrete, then wall to that
Ok, so I am having a few issues in my garage, the biggest of which is water coming in from the rear of the structure. The garage sits very low on the property, and it is fairly level, but the slight slope goes straight to the corner of the garage. When we get a decent raint, i get water in the garage.
What I would like to do is to support the garage walls, cut the bottom part out, and replace it with some concrete block, either 4 or 8" tall, which will give me the height i need to keep the water out.
My question is, how would I go about attaching it to my slab to make it water-proof? Do i just use regular morter or is there a special bonding agent? Will I need to drill into the concrete and fill the spaces with concrete? This will only be one course of block and a new sill plate for the garage.
Thanks.
jimmyfloyd is offline   Reply With Quote
Old 03-29-2010, 12:58 PM   #2
Xtreme DIY'r
Is the garage wall curently bolted down/secured to the cement pad ?
Where is the water coming in ?
Between sill plate & floor ?
You would need to dig down & seal the new block to the pad/foundation
Might be better/easier to dig down & put a drain system in that directs water away
Old 03-29-2010, 01:34 PM   #3
The garage may be secured to the pad, but I don't see any bolts coming through along much of it. The water comes from between the pad and the sill. The ground outside is about 1-2" over the top in area. The ground is really level, so doing much drainage isn't really going to work, plus part of the area is paved, so I couldn't get under that.
I can get better pictures of the area later today.
This is the back of the garage (mine is the left, neighbor's is right):
And this is it in relation to the house. about 3 ft in front of the fence and 20' behind it is paved.
The water enters mostly from around that back corner by the gate in the first picture and the side door in the second.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Depth of the flower garden next to the concrete wall ? cprao Landscaping & Lawn Care 12 10-28-2009 11:12 PM
join poured concrete wall to CMU wall? walkman Building & Construction 1 10-01-2009 09:17 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
