Old 04-17-2012, 12:13 AM   #1
attaching a bird mouth to the top plate
Not too sure if my lingo is proper..my problem is I'm fairly new at building and especially weak in the roof area..I'm building a camp 12x16, I have 3 of 4 walls up and my next step is rafters..I can't figure out how to screw or nail the bird mouth to the top plate..any suggestions would be a big help
doobs1998 is offline   Reply With Quote
Old 04-17-2012, 12:22 AM   #2
It's nailed in place with the nails at an angle.
It's called toe nailing.
Old 04-17-2012, 07:40 AM   #3
Framing Contractor
Originally Posted by doobs1998
Not too sure if my lingo is proper..my problem is I'm fairly new at building and especially weak in the roof area..I'm building a camp 12x16, I have 3 of 4 walls up and my next step is rafters..I can't figure out how to screw or nail the bird mouth to the top pl ate..any suggestions would be a big help
Toenail. Seriously, if you don't know how to fasten a rafter to the top plate you need someone with experience helping you.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-17-2012, 07:46 AM   #4
Have you already installed the ceiling joists? If you put up rafters without ceiling joists, the walls will bow out and the ridge will sag. The rafters get nailed to the top plate with toe nails and to the ceiling joists also.
packer_rich is offline   Reply With Quote
Old 04-17-2012, 08:59 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
toenailing in combination with hurricane ties to strengthen the connection
woodworkbykirk is offline   Reply With Quote
Old 04-17-2012, 11:10 PM   #6
Moderator
Use the first 6 Items: http://publicecodes.citation.com/ico...002_par031.htm
Last Chart at bottom and "Adjustment factor" for ceiling joist/rafter nailing: http://publicecodes.citation.com/ico...002_par023.htm
Gary
P.S. Welcome to the forums!
Clothes taking longer to dry?
Attaching floor joist to cap plate Mikey92x Building & Construction 1 10-30-2010 04:38 PM
Does anybody use/suggest Ramset pins for attaching base plate to cement? jobblyman Building & Construction 23 10-30-2010 12:39 AM
Attaching bottom plate to concrete at edge near wall BlueBSH Building & Construction 13 06-13-2010 05:05 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
attaching top plate to existing ceiling derek9 Carpentry 5 07-30-2009 08:14 PM
