Attaching An Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 07:22 PM   #1
attaching an addition
How can I attach an addition room wall to a vinyl wall with osb behind
visionary is offline   Reply With Quote
Old 02-23-2009, 07:24 PM   #2
Vinyl wall? Vinyl siding?
Are you building the addition?
Already built & putting up siding?
Old 02-23-2009, 07:30 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
are you referring to vinyl siding over OSB? If so you must remove the siding and fasten your framing to the house framing . You must install a pocket stud inside the existing wall so you have something to fasten the end stud to.this is the correct way to tie in an addition. BOB
Old 02-23-2009, 07:35 PM   #4
Vinyl sidding, i can see were the osb is nailed to the studs, also the neww walls top plate is 18" lower than the vinyl wall top plate , how do i over come this
Old 02-23-2009, 07:40 PM   #5
buletbob's Avatar
you could install blocking to fasten the top plate, the best bet would to post a picture of the area in question, then we can better advise you. BOB
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 06:06 PM
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 11:43 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 08:59 PM
