Originally Posted by dweagle
I thank both of you for your quick replies. The posts will be free standing with the railing connecting each post. They will not be tied into another stationary object. Will these U brackets keep the railing from moving if someone would lean against it? I am familiar with galvonized joist brackets and they are easily bent, so I am assuming these U brackets are of the same construction.
I found some posts at Lowes that have a decorative cap and are already pre-notched at the bottom. The notch is about six inches long and is about 2 inches deep. If I were to use these posts what is this epoxy that AtlanticWBConst speaks of? Do you drill the holes in the concrete, put some epoxy in the hole, and then place your sleeve anchor and lag bolt?
To your questions:
(First paragraph) NO, yes.
(Second Paragraph) .....any strong adhesive epoxy (Check at any BIG HOME improvment store in a the glue dept - Get the right kind).... and yes...to the last question.
Use a good masonry bit. The sleeves get hammered (tapped) into the opening-you want a tight fit. The Epoxy acts like a cement and bonds the sleeve to the block/concrete.
