Attaching 2by4's To Lap Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2007, 02:23 AM   #1
attaching 2by4's to lap siding
Has anyone ever gotten a good seal by tacking 2bys to lap siding?
I am constructing a shed shop against the side of my house and need an idea for sealing
boavirett is offline   Reply With Quote
Old 12-15-2007, 07:35 AM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
cut the 2x4 to fit the siding or cut the siding out the way. Calking the gap left by nailing over the siding is not a good idea but you could do it and stuff the gap with backing rod.
Kingfisher is offline   Reply With Quote
Old 12-16-2007, 03:22 AM   #3
2by4onlapside
thanks I'll just cut some sort of template and go from there
Old 12-16-2007, 03:23 AM   #4
by the way what is backing rod?
Old 12-16-2007, 07:45 AM   #5
foam rod that you shove in large gaps before caulking them. It saves you from using an entire tube of caulk on one lineal foot of gap by giving the caulk something to flow in against. The foam fills the gap, and then you cover it with a bead of caulk.
You'll find it near weatherstripping at Home Depot/etc.
NateHanson is offline   Reply With Quote
Old 12-16-2007, 08:23 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's actually called: "Backer Rod", Here are some links that can explain it:
What it looks like: http://www.mysimon.com/9000-11020_8-...oam+backer+rod
Examples of how it is used: http://www.bayindustries.com/backerrod/milehigh.html
- Build Well -
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
