-   -   attaching 2by4's to lap siding (http://www.diychatroom.com/f19/attaching-2by4s-lap-siding-14441/)
boavirett 12-15-2007 01:23 AM
Has anyone ever gotten a good seal by tacking 2bys to lap siding?
I am constructing a shed shop against the side of my house and need an idea for sealing
Kingfisher 12-15-2007 06:35 AM
cut the 2x4 to fit the siding or cut the siding out the way. Calking the gap left by nailing over the siding is not a good idea but you could do it and stuff the gap with backing rod.
boavirett 12-16-2007 02:22 AM
2by4onlapside
thanks I'll just cut some sort of template and go from there
boavirett 12-16-2007 02:23 AM
by the way what is backing rod?
NateHanson 12-16-2007 06:45 AM
foam rod that you shove in large gaps before caulking them. It saves you from using an entire tube of caulk on one lineal foot of gap by giving the caulk something to flow in against. The foam fills the gap, and then you cover it with a bead of caulk.
You'll find it near weatherstripping at Home Depot/etc.
AtlanticWBConst. 12-16-2007 07:23 AM
It's actually called: "Backer Rod", Here are some links that can explain it:
What it looks like: http://www.mysimon.com/9000-11020_8-...oam+backer+rod
Examples of how it is used: http://www.bayindustries.com/backerrod/milehigh.html
