Attached Patio Overhead Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 04:21 PM   #1
I am installing a 9' high patio roof on a 5 1/4" slab. The roof will be attached to a house wall. The area is 10 1/2' along the house wall and if I put a shed roof on a ledger the span is 9' from the ledger to the 4"x4" posts. I will use a 2" x 6" ledger. The roof will have about nine 2"x4" rafters on 12" centers and 3/4" OSB sheeting plus the weight of a layer of asphalt 3-tab shingles.
How many 4"x4" posts do I need to support this span?
Also, if I decide to make an attached gable roof instead would I need the same number of 4"x4" support posts.
Gandalf is offline   Reply With Quote
Old 04-18-2010, 04:28 PM   #2
Rewards Points: 5,336
The structure you describe is inadequate for the job, even in a southern region. The 2x4 rafters are inadequate. for one. It would help if you posted where you live.
Ron
Old 04-18-2010, 06:00 PM   #3
In Denver Colorado. Why inadequate? The IRC codes say that with a 30 psf ground snow load that 2"x4" rafters on 12" centers can span 9'5".
Old 04-18-2010, 07:00 PM   #4
What type/grade of wood are you using to get the 9' 5" span ?
Old 04-18-2010, 11:53 PM   #5
Registered User
Rewards Points: 5,230
You may want to give a call to your local Building Department.... My 2003 IRC says 2x4, 12"o.c., Douglass fir, will span 9'10" with NO SNOW load.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 04-19-2010, 11:30 AM   #6
It is the douglas fir they sell at home depot.
Old 04-19-2010, 11:54 AM   #7
I'm getting only 7' 6" for span w/30psf snow load
2x6 will get you 10'+ easily with 16" OC
Old 04-19-2010, 12:43 PM   #8
Thanks Dave. So that's about 9 ten foot 2 x 6 boards. How many 4" x 4" support posts do you think I should use?
Old 04-19-2010, 12:53 PM   #9
You are coming out ~9' 5" from the house ?
For 2x6 rafters use a 2x8 ledger & hangers for better support
If your roof will be 10' 6" along the house you really only need (2) posts at the outside corners
Instead of 4x4's go to 6x6's or 4x6 at the very least
Cut & notch the top & run a beam between the 2 posts to support the rafters
What kind of slope will you have on this roof ?
Low slope I'd probably go to 2x8 rafters for that one heavy snow storm
Since this will be attached to the house you are supposed to dig down & pour piers for the posts to sit on - down below frost depth for your area
Pics might help to see what you are dealing with
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Gandalf (04-20-2010)
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Patio Roof Issue: Water or Paint Wearing Off? kirridam Roofing/Siding 6 10-22-2009 06:31 AM
Patio Roof Renovation freddie Roofing/Siding 4 11-01-2006 10:01 PM
