Attached Garage Without Footings? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 08:31 PM   #16
concretemasonry's Avatar
Rewards Points: 2,608
Joe Carola -
Just a clue, you are referring to the Republic of Wisconsin, as it was referred to a few years ago in a friendly way. They are famous for adding local conditions, but not always enforcing them. In the past they would poorly change the model codes and not realize the loop holes they created or that prevented some nationally known products from being used.
I am not far from northern Wisconsin and am there frequently. The knowledge and affect of the codes are hit and miss situation. - Good people, but poor administration and controls from the top.
Dick
concretemasonry is offline   Reply With Quote
Old 07-31-2011, 10:16 AM   #17
Ive done it
Ok here's the way it's done in northern Ont. Canada.
First your building dept. will give you what is required
in your area. In my case it required an eng. drawing of
the slab showing how it was to be done. This drawing
showed all insulation that is required around the slab
and under it, pinning to the existing building ect. It
also must be heated to a min. of 40 F all winter.
If there is little traffic around the garage the frost will not
be a problem.
By the way the gentleman that said clay does not move
is out of his mind! It;s the worst there is! I've seen it heave
2-3 feet.
Hope this info is of some help
not mike homes is offline   Reply With Quote
Old 07-31-2011, 11:05 AM   #18
Tom Struble's Avatar
Rewards Points: 2,002
frost heave and expansive soil are 2 different things
Tom Struble is offline   Reply With Quote
Old 07-31-2011, 11:28 AM   #19
Concrete & Masonry
Rewards Points: 582
Originally Posted by Joe Carola View Post
Building department has no codes?
In alot of the more rural areas of N. WI, there simply aren't building departments. Until maybe 5-8 years ago, most of these areas didn't even require building permits for new dwellings, much less remodeling, additions, alterations, etc... The state passed legislation requiring the entire state to require building permits & subsequent inspections at that time, but most areas never put together their own depts, so the state supplies them with the inpection companies. It's put out to bid on a multi-year contract, and the results are less than stellar. Oftentimes, the independent inspector is onlyy available 1 day a week, they can be very un-responsive, and typically won't help guide you along the way. They often feel their job only entails a "pass or fail" inspection, and it's up to you to do the legwork.
Originally Posted by concretemasonry View Post
Joe Carola -
Dick
See Dick, here we refer to it as "The Peoples Republic of Madison", as what happens there usually doesn't represent the balance of the state accurately. We do indeed have some differing "opinions" from inspectors on code issues, but they are fairly uniform from area to area.
jomama45 is offline   Reply With Quote
Old 07-31-2011, 12:26 PM   #20
Civil Engineer
Rewards Points: 4,792
Clay vs. silt
The comment that clay moves 2 - 3 feet likely refers to silt. Clay is a mineral that tightly binds water to it chemically. The water in clay is not free, and cannot freeze. Silt, on the other hand, refers to small (less #200 sieve) particles which do NOT bind water tightly. Silt is notorious for frost heave, as is very fine sand.
Unfortunately, silt and clay feel similar, and in some cases look similar, hence are often confused. There are sections of the US that have "red clay", which is often silt. So my point is that true clay almost never heaves, but since silt is often mistaken for clay, clay gets a bad reputation for frost heave.
Old 07-31-2011, 02:00 PM   #21
I live in similar weather conditions and built an attached garage with the slab and footings done in one pour. I dug a perimeter trench and formed up the outside with 4, 2X8s.
In my case, for whatever reason, the slab dropped about 1" on the side adjacent to the house.
Fortunately, the slab had fall, so now its just about level.
I would never, ever use this method again. The slab should be supported on piers in our climate. The piers must have footings that are 48" below grade.
Wall between attached garage & interior - waterproofing cham44 Building & Construction 8 08-20-2010 11:27 PM
Motion Activated Light for Attached Garage jamiedolan Project Showcase 6 07-01-2010 12:52 PM
100 amp Attached Garage Sub Plan KevinBeamer Electrical 18 10-04-2009 08:11 AM
garage remodel footings james schroder Building & Construction 2 09-01-2009 10:30 PM
6/4 AL for Attached Garage Sub Panel theatretch85 Electrical 3 04-28-2009 01:32 AM
