Attached Garage Wall Cracks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 08:28 PM   #1
I have an attached garage with a concrete slab floor and concrete walls. There is a large horizontal crack about 3 1/2" up from the floor on the inside of the outer wall. What is the best way to repair this crack? Since it would be difficult to get concrete mix into the crack, is there a caulk of some sort that could be used?
bkikkert is offline   Reply With Quote
Old 07-22-2008, 09:52 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Yes. Go to Sherwin Williams and ask for their "Elastomeric caulk".
Sir MixAlot is offline   Reply With Quote
Old 07-22-2008, 10:12 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
also do some research on why the crack is there. epoxy injection, is another option for structural damage.
Old 07-22-2008, 10:27 PM   #4
x/builder
Concrete crack repair 101
Very common problem, If the crack is very small and mortor could not easily penetrate you can enlarge the crack. This is standard procedure and will aid in a strong bond to the wall.
If the wall is painted them you must chip off the paint or the mortor will not stick.
There is a excellent product called "top and bond" that will do a great job, it sticks to anything except paint. If you want to make it even stickyer you can buy additional bonding additives.
Read your instructions and fallow them and no more crack
FrankTheTorontoRealtor is offline   Reply With Quote
Old 07-23-2008, 07:38 AM   #5
from your mouth to God's ear, frank,,, i can't even tell if the problem's been described properly
yesitsconcrete is offline   Reply With Quote
Old 07-23-2008, 08:48 AM   #6
concretemasonry's Avatar
Rewards Points: 2,578
bkikkert -
What is behind the garage wall? - Is it soil?
Usually, a horizontal wall is a structural issue and a classic sign the wall has slightly failed.
concretemasonry is offline   Reply With Quote
Old 07-23-2008, 09:33 AM   #7
The garage is attached to the house and on the unattached sides, the wall comes up about 28 inches from the concrete slab. I do not know how far it goes into the ground but I suspect not much further than the bottom of the slab.
The age of the house and garage is 36 years.
Wall Panel Over Sheetrock in Garage kypper Building & Construction 1 07-03-2008 08:57 AM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 10:47 AM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 11:23 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
