Attached Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 07:18 PM   #1
attached garage
Hi, need some direction on the proper method of securing a non load
bearing wall that runs in the same direction as the trusses.Bottom is
secured to the floor. How do you tie in the top of this wall to the building?
not mike homes is offline   Reply With Quote
Old 07-21-2011, 10:15 PM   #2
AGWhitehouse's Avatar
cut 2x4 blocks to fit in between the two trusses that will be on either side of the wall. Lay them flat and attach to the trusses so they are flush with the bottom of the truss. Attach you top plate to these blocks.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-22-2011, 10:01 AM   #3
attached garage
Thanks AG if only it were that simple. The wall in question is an outside wall, the next closest wall is the original house 16' away. Does this mean
I must start at the house and put blocks inbetween all the trusses from there to the outside wall to tie in ? and in how many locations along
the 32' wall.
Old 07-22-2011, 10:42 AM   #4
Huh? Is this a kind of "fence"? You're building a single wall 16' away from your house? Maybe a quick sketch or some pictures will help me understand what you're after here.
Old 07-25-2011, 08:35 AM   #5
Ok, the gagage has 3 walls. 2 end walls attached to the hoiuse. These 2 walls are 16' the outside wall that runs between the 2 end walls is 32'.
The 2 end walls are load bearing with the trusses running the full 32'.
I need to know the proper method of keeping the outside wall plum.
I hope this helps
Questions regarding wiring 220 to attached garage... John Green Electrical 0 01-20-2011 09:23 AM
OSB over sheetrock in attached garage Badfish740 Building & Construction 6 01-15-2011 03:37 PM
100 amp Attached Garage Sub Plan KevinBeamer Electrical 18 10-04-2009 08:11 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Attached Garage Wall Cracks bkikkert Building & Construction 6 07-23-2008 08:33 AM
