Attached Carport Support Beams Need Replaced. Please Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 10:35 PM   #1
Attached carport support beams need replaced. Please help!
Hello,
First time homeowner and found a fixer upper in need of some work. I have many projects and I need this one done before I start the next.
I need to replace the support beams of the attached carport, it is a 16'x24'. The concrete slab has settled and cracked. It also looks like someone backed into the outside post, causing the support to be pushed out along with the weight of the roof.
Attached carport support beams need replaced. Please help!-forumrunner_20120807_223345.jpg
Attached carport support beams need replaced. Please help!-forumrunner_20120807_223413.jpg
Attached carport support beams need replaced. Please help!-forumrunner_20120807_223426.jpg
My plan was to build a temp wall, knock out the old wall. Bust up the concrete enough to dig holes for new piers and set the new post.
Is this a good way of going about this or are there other options our opinions? I appreciate all feedback and help!
marengo pike is offline   Reply With Quote
Old 08-08-2012, 02:50 PM   #2
Rewards Points: 3,364
Why build a temp wall,save yourself some work and just use a 4x4 for support while you remove the wall for new piers or footings.
Canarywood1 is online now   Reply With Quote
Old 08-08-2012, 03:52 PM   #3
That is a good point. I guess I was thinking a temp wall would be tied together and spread the weight out more evenly.
Old 08-08-2012, 07:50 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
The beams are what will need the support and just one or two 4x4s aren't enough. I would place the 4X4s where the support posts are now, or right next to them. If I were doing it I would have a 4X4 inside and one outside at each post, to keep the beam from twisting. You will need to put the 4X4 on something on the outside to keep it from sinking into the ground. That is a dangerous situation the way it is now and it won't take much for it to come down.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-08-2012, 10:15 PM   #5
Thanks for your response. Yes it is on its last leg. I framed a wall on the inside of the carport. So hopefully that will hold till I can replace the post
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
roof support beams dwhelton Building & Construction 1 10-16-2010 01:08 PM
Laminated support beams for 25 foot long footbridge. fifty7flash Building & Construction 7 10-09-2010 06:03 PM
Building Attached Carport MikeVila Building & Construction 4 01-12-2009 05:23 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 10:18 AM
