Attach Laundry Sink To Concrete Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 07:18 AM   #1
sweaty
Rewards Points: 276
Attach Laundry Sink to Concrete Floor
I am installing a new laundry sink. It is fairly lightweight and I am concerned about someone accidentally bumping into it and damaging the drain connection. There are holes in the feet to fasten it to the floor.
I want to fasten it to the concrete floor, but do not want a big penetration into my foundation; just something strong enough to hold it firm. Would I use nails or screws? What kind? I just have a hammer and a decent corded drill. I want to be able to take it out.
sweaty is offline   Reply With Quote
Old 01-21-2012, 07:41 AM   #2
Rewards Points: 1,578
Tapcons would work; drill a short hole, screw it in, might need a washer on the screw head.
bob22 is offline   Reply With Quote
Old 01-21-2012, 07:44 AM   #3
MarginallyQualified
Rewards Points: 2,464
I'll tell you how I've done it. OK?
1) Pin the plastic legs into the sockets they slip into.
2) On the bottom of the FRONT legs pin a 1" x 3" scrap of stainless steel
(18ga is plenty; drill a pair of pilot holes at each end first)
2a) Plastic anchors into the floor (or tapcon)
3) With two more 1" x 3" scrap pieces of s/s make a pair of angle brackets (with 2 holes ea)
4) Find at least one of the studs behind your sink location (if not block)
(through screw from the faucet ledge into the angle bracket).
Use stainless hardware for everything.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Floor Joists on Concrete loftezy Building & Construction 1 02-23-2011 04:09 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 01:07 PM
