Attach Bike Rack To Double Wythe Brick Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 07:27 AM   #1
Attach Bike Rack to Double Wythe Brick Wall
Hey everyone, my wife and I just ordered some nice new bikes this weekend. We're planning on biking to work to see if we can help put off getting older for a while. We live in Washington, DC which means storing bikes outside is a dangerous prospect. Unfortunately, my mother-in-law lives in our basement, so the bikes get to live outside. We'll eventually have a deck with a relatively enclosed underside, so I'll just install a couple of bike posts and we'll call it good.
But until then, I've got to come up with something. We do have a small cement patio over the basement entrance, so if I keep them there, at least they'll stay dry. As far as keeping them safe, the best I've seen so far is this, a locking vertical bike mount. Seems to fit the bill, but I am definitely open to any and all suggestions. Barring any remarkable alternatives, my real question is, what's the best way to go about bolting this to the wall? I suppose I could use an epoxy bolt, expansion bolts, hammer anchors or even tapcons. The bikes aren't terribly heavy, but I want to make sure this can't simply be forced off the wall with a crow bar. Also, is there a type of anchor out there that cannot be unscrewed/removed? I'd hate for the neighborhood punks to get smart one day and find a screw driver, right?
So, any thoughts?
stubits is offline   Reply With Quote
Old 05-10-2010, 08:02 AM   #2
kwikfishron's Avatar
Rewards Points: 344
http://www.concretefasteners.com/anc...ion/index.aspx
You can get them at any hardware store.
Probably won’t work with any fasteners that come with the rack so you’ll have to buy new and maybe have to drill a bigger hole.
kwikfishron is offline   Reply With Quote
Old 05-10-2010, 08:04 AM   #3
Excellent. Thanks! Any thoughts on a fastener that cannot be easily removed? To prevent thugs from just unscrewing the whole deal from the wall?
Old 05-10-2010, 08:10 AM   #4
Rewards Points: 344
It will actually be a bolt they would have remove to get the rack off the wall. Don’t know what more to do other than lock it but even locks are only good for keeping the honest crooks out.
Old 05-10-2010, 08:15 AM   #5
Rewards Points: 344
You could always grind on the bolt head. Damage it enough so a wrench won’t work.
Old 05-10-2010, 08:19 AM   #6
Good idea. Then when the time comes for me to actually remove it, I guess I could hack it off with a reciprocating saw, right?
Old 05-10-2010, 08:24 AM   #7
Rewards Points: 344
That or grind it off.
Old 05-10-2010, 08:34 AM   #8
http://www.bikeparking.com/btwlockerp/index.html
mark942 is offline   Reply With Quote
Old 05-10-2010, 08:38 AM   #9
Thanks Mark, but BIG difference in price, no? Plus it would consume our whole yard!
Old 05-10-2010, 10:56 AM   #10
If you can access both sides of the wall you could attach everything with carriage bolts or vandalism-proof / resistant bolts. http://www.brycefastener.com/
cellophane is offline   Reply With Quote
Old 05-10-2010, 10:59 AM   #11
Cellophane- That's awesome, but won't work in my application. It is a finished basement, so it just won't work. But thanks, and very cool.
Old 05-10-2010, 11:15 AM   #12
Rewards Points: 344
The might have these at the hardware store.
http://www.tufnutworks.com/category....Security_Bolts
Second item down the page.
Old 05-10-2010, 11:27 AM   #13
What about ceiling mounting them inside? I've seen some nicely done places on some design blogs where bikes were hung up inside and treated as a focal point.
Old 05-13-2010, 10:32 AM   #14
Bike Storage in Honor of National Bike to Work Month
Insulating double brick wall home. Via the inside. the punisher Building & Construction 20 05-19-2010 08:16 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
Doorway though brick wall. archangel689 Building & Construction 3 04-20-2007 09:23 AM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
