Attach 1x3 To CMU Wall W/out Hammer Drill? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 12:59 PM   #1
Attach 1x3 to CMU wall w/out hammer drill?
Is it possible to attach some wood 1x3 cleats to a CMU wall without a hammer drill? We just have a regular drill... thoughts?
I don't know if this makes any difference but this will be on the exterior...
smoochas is offline   Reply With Quote
Old 08-08-2010, 05:34 PM   #2
You don't HAVE to have a hammer drill to drill concrete. You'll just wish for one after using a regular drill with a mansonry bit.
A very sharp masonry bit may do the job without hammering.
Masonry is very hard, but brittle. As a result, abrading it away is very inefficient--it's too hard. But if you hammer it, it will break off and the flutes of the bit just auger the pieces/dust away.
Every notice that the bigger the masonry drilling job, the more it relies on hammering rather than drilling? This is no accident.
If you haven't a hammer drill, I'd recommend one of two options:
1) Rent an SDS drill. The Slotted Drive System bits (pioneered by Bosch) drill MUCH faster than a regular hammer drill and save a ton of time. The SDS design gives much more hammering action, and hammering is what masonry drilling is all about:
[youtube]SKDIggpbXqU[/youtube]
2) Use a powder nailer. These work pretty will for attaching to concrete. They attach thing securely and quickly (hence, so many "production" builders use them). Only downsides imo are lack of do-overs. A powder-driven fastener damages concrete when removed. Better to cut off and leave the stub in the concrete. They also take a little dialing in to match the charge energy with the fastener (called a "pin") and material density.
I'd personally choose option #1, as a quality concrete screw (GRK's Caliburn is the best available IMO, but a Tapcon works well also). They are more secure and less damaging/stressing to the CMU.
Hohn is offline   Reply With Quote
Old 08-08-2010, 05:54 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I would just buy the Ryobi hammer drill. It's around $69. A concrete bit is made to chisel out the material not cut it like a wood bit. I spent about 2 hours trying to drill a hole with a normal drill. I got fed up and sprang for the Ryobi. The same hole took about 5 seconds with that drill.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-09-2010, 05:53 AM   #4
Rewards Points: 1,216
Harbor Freight has a cheap hammer drill for about 20 bucks and cheap bits.
If you are only using it for the 1 job why not.
COLDIRON is offline   Reply With Quote
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Drilled into metal in wall, now drill bit is magnetized... rehabhell Carpentry 16 02-18-2010 09:07 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
How to Drill Porcelin/Ceramic Wall Tile tmbrink Kitchen & Bath Remodeling 3 02-27-2009 06:14 PM
How do I drill the hole in the wall if I don't know location of electrical wire popkadurak Remodeling 10 06-16-2006 10:06 AM
