Asphalt Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 11:06 AM   #1
Rewards Points: 129
Asphalt repair
I hope this is the right forum for this question - We live on a private road that is shared with eight homes. We are responsible for the upkeep of the road. Our road is asphalt, 4" thick. There are some cracks developing in the asphalt that I want to fix before they expand. Here is my plan: clean out debris in crack with wire brush/compressed air - place sand in cracks that are deep (over 1/4"?) - heat repair goop until it flows smoothly - pour into the crack. Does this sound like a proper repair? Suggestions are appreciated. Thanks
Jack E is offline   Reply With Quote
Old 03-11-2011, 01:24 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... Donno just what you're calling "Goop", but...
The sand goes over top of the sealing tar, not under it....
Old 03-11-2011, 02:40 PM   #3
Rewards Points: 129
Sorry, I was at loss for the proper term How much sand would you place on top of the sealing tar? Thanks
Old 03-11-2011, 06:54 PM   #4
Rewards Points: 4,656
you've got the right idea but you'll be cracksealing, not repairing,,, what you describe is commonly known as ' glow 'n' seal ' 'cept you're including wirebrushing prior to the blow if the cracks're only 1/2", nothing's needed,,, over 1", fill w/vermiculite/sand 50/50 mix UNLESS you want the real stuff which is a hot-pour backer rod,,, in your sit, i wouldn't.
the hot repair ' goop ' should be astm d1190 material which can be heated & applied in a direct fire melter then installed w/wheeled ' overbander ' e never ' salted ' the work as we had the lane closed
The Following User Says Thank You to stadry For This Useful Post:
Jack E (03-15-2011)
Need advice on 1 1/2 inch of asphalt overlay on concrete and old Asphalt stanlam Off Topic 9 12-05-2010 07:46 PM
Need advice on 1 1/2 inch of asphalt overlay on concret and old Asphalt stanlam Landscaping & Lawn Care 1 11-28-2010 04:50 PM
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
Asphalt repair in snow country Steve Burke Building & Construction 2 09-19-2009 05:34 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
