Asphalt Needed At End Of Driveway. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2008, 12:40 PM   #1
Rewards Points: 164
Asphalt needed at end of driveway.
At the end of my drive where the drive meets the roadway there is a patch that needs more blacktop. Can I buy a bag of blacktop patch/ repair or it only comes from a company or dept of road. If there is something out there does it need to be heated? HOw will it adhere to the old asphalt and not crumble away?
68MHJCs is offline   Reply With Quote
Old 08-25-2008, 11:28 PM   #2
Rewards Points: 164
Nobody has any input on this????????????
Old 08-25-2008, 11:33 PM   #3
You can use a cold patch product like this: http://www.coldasphalt.com/
ShawnPA is offline   Reply With Quote
Old 12-07-2010, 07:03 AM   #4
hi,
you can use a COLD MIX product which you don't have to head and can buy a single bag which could be easily implemented on patch.
Gloriaray is offline   Reply With Quote
Old 12-07-2010, 08:40 AM   #5
A Little Of Everything
Rewards Points: 1,364
Not sure where you live, but here in Omaha that part of the driveway is the responsibility of the city.
DrHicks is online now   Reply With Quote
Old 12-07-2010, 08:48 AM   #6
Registered User
Termite's Avatar
Cold patch is kind of like a band aid. It'll fill holes or can be tamped into open cracks. But it isn't a really permanent fix. To correctly repair the driveway the old asphalt needs to be removed/milled down and re-laid, or at least patched with hot patch. Hot patch isn't a DIY thing, so cold patch is probably your best bet until you're ready for a new drive.
Edit: just realized this thread is two years old.
Old 07-18-2011, 02:21 AM   #7
Yes you can use cold mix and cold patch asphalt for the same.
Semina is offline   Reply With Quote
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
Asphalt Driveway Seal mbwolvs General DIY Discussions 1 11-06-2007 07:05 PM
asphalt grindings driveway DIY? johnny331 Landscaping & Lawn Care 2 09-28-2007 05:37 AM
driveway, concrete or asphalt? johnny331 Building & Construction 2 06-19-2007 11:03 PM
Painting an asphalt driveway surfitness Painting 4 08-25-2005 12:08 AM
