Asphalt Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 02:05 PM   #1
Rewards Points: 109
asphalt driveway
I have a concrete pad that butts up against the asphalt driveway. In the winter when it heaves it always cracks the edge of the asphalt. I want to have a new driveway put in should there be something between the edge of the asphalt and the concrete?
hitmehhh is offline   Reply With Quote
Old 01-20-2010, 02:55 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Nope,... The basic blacktop to concrete interface is just Fine the way it is...
You should figure out Why it's heaving,+ Fix that...
It's usually caused by improper drainage,+ a backup of groundwater Under the area that's heaving....
Old 01-20-2010, 07:07 PM   #3
Licensed Engineer
Rewards Points: 175
Seal the joint
The only thing that should be between the two dissimilar paving materials is sealant. Hot rubber is best, but for a small D-I-Y job I would use Sonneborn SL-1, or Sikaflex, or equiv. Just make sure it is compatible with asphalt and concrete.
I used Novalink SL on my concrete driveway because it is much faster drying, only two days until full cure. Note - Novalink SL is not recommended for use with asphalt.
MI-Roger is offline   Reply With Quote
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
Patching holes in asphalt driveway joe3534 Landscaping & Lawn Care 5 11-22-2009 09:16 AM
Asphalt driveway tripower Building & Construction 1 12-31-2008 01:19 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
asphalt grindings driveway DIY? johnny331 Landscaping & Lawn Care 2 09-28-2007 04:37 AM
