Asphalt Driveway? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 11:36 PM   #1
Asphalt driveway?
Have many older trees around my property... And as such the concrete driveway heaved... Slabs are cracked and for the most part diminished! Looking at getting a new driveway... With the network of root systems underneath is asphalt a plausible consideration? Figured it has some give to it and can be easily resurfaced... Live in southern Ontario Canada.
stoked91 is offline   Reply With Quote
Old 05-18-2011, 11:41 PM   #2
Rewards Points: 558
You would have to fix your problem first (the roots) not just put a band aid on it. You will have the same problem down the road if you donít correct your problem.
epson is offline   Reply With Quote
Old 05-18-2011, 11:45 PM   #3
Not looking at getting rid of the roots... They are old character trees... Willows, elms, and such...the roots by no means protrude the ground... But I'm sure with summer and winter... Hot/ cold/ wet/ dry... They have caused some of the heave...
Old 05-19-2011, 12:42 AM   #4
In a little over my head
Rewards Points: 706
Make sure you fix the oil leak on your car/truck, or you'll quickly have an ugly soft spot.
ratherbefishing is offline   Reply With Quote
Asphalt Driveway erb170 Building & Construction 7 10-24-2011 06:22 PM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 04:42 PM
Spreading cement over asphalt driveway? Dagz Building & Construction 1 09-06-2010 08:55 PM
Patching holes in asphalt driveway joe3534 Landscaping & Lawn Care 5 11-22-2009 10:16 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
