Asphalt/concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2010, 12:53 PM   #1
asphalt/concrete
Main question is will concrete bond watertight to existing asphalt ? We are building a water barrier around a building and in place is a small (not enough) asphalt barier, we need to built this up.
tbbbmb is offline   Reply With Quote
Old 06-22-2010, 06:52 AM   #2
Rewards Points: 4,534
waterproof barriers are modified asphalt cement,,, asphalt & concrete do not ' bond ' to each which's why that joint is sealed w/joint sealant.
if you could defing ' water barrier ' that would be a large aid in understanding the thread.
