Asbestos Wrapped Heat Ducts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 12:04 PM   #1
Asbestos wrapped heat ducts
what can I do about asbestos wrapped ducts that is cracking? Is it safe to leave it alone?
marycaselli is offline   Reply With Quote
Old 06-29-2010, 01:28 PM   #2
Totally screwed together
Is it cracking because it is getting knocked into?
Has your HVAC system changed at all over the years - did anyone open it up or add/remove any lines?
There is a product called "encapsulant", it's kind of like watery elmers white glue. It gets sprayed on asbestos covered things, and it seals in the asbestos so it doesn't flake away. I'd suggest that AS LONG AS no one has made any changes to the system.
At my house, they did make changes, some of which included slipping the insulation inside the air channels
xxPaulCPxx is offline   Reply With Quote
Old 06-29-2010, 01:54 PM   #3
Exclamation
Rule of thumb
It is my understanding that if you don't touch the asbestos you are safe. You do not want to get any fibers in the air that you or your loved ones can inhale.
Ted da man is offline   Reply With Quote
Old 06-29-2010, 02:20 PM   #4
If it's cracking, it's already been touched. Now the question is what to do.
BTW, the original poster should fill in the profile so we know where they are located!
Old 06-29-2010, 03:49 PM   #5
Rewards Points: 156
Some of my ductwork that was running through my garage was covered with asbestos insulation when I moved in. I sprayed it down with soapy water to keep any of it from flaking away while I covered it with new duct insulation. I also wore a dust mask of course.
Branden is offline   Reply With Quote
Old 06-29-2010, 06:36 PM   #6
Honestly you have a situation. The only way to confirm the contaminent in the house is to have it tested. Thats also very expensive. Do not I repeat do not attempt this at home. They way to do this properly is professionally and there is very strict proceedures on removal.
Imagine a bio lab leaking a hazardous substance. Remember someone dying in that lab. Remember those hazmat people. Sanitation doors and decontamination units. Not to scare you but thats typically how hazardous substances are removed. DO NOT TRY IT.
Your life is more important to me personally, is it an expense yes but don't think for a second this is as easy as putting on a mask.
FYI stay clear of this DIY
Just a thought
Bldg 2 Spec is offline   Reply With Quote
Botched asbestos removal in home... runfrombears General DIY Discussions 28 07-31-2012 10:21 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Programmable thermostats, heat pumps and aux heat Crunkleton HVAC 3 04-21-2009 06:17 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
