Old 12-17-2009, 07:23 PM   #1
Asbestos pad in wall?
I found this little grey pad in the wall providing padding for some electrical conduit rubbing against the inside of the drywall. its very old and brittle.
Could it be asbestos?
Kreed is offline   Reply With Quote
Old 12-17-2009, 07:53 PM   #2
Household Handyman
"Kreed", I suppose anything could contain asbestos, and the only way to tell would be to have it or a sample tested. That certainly looks like "random pattern felt" though. I'm not real sure if I have the name exact, but I do remember something like that. We used to use something that looked very much like that at work for heat insulation. It came in various base colors with mixed colored strands woven into it. I always thought it was made from some type of scrap material. The material we bought was placed in between surfaces which were very warm (not too hot) and surfaces we didn't want the heat to transfer to in a temporary situation until we developed a permanent situation. Some of those "temp" applications were still on the equipment for twenty years or so. I don't remember ever using ours in an electrical application, even though you state it was between electrical conduit and drywall. Maybe it was just that, a padding to prevent the conduit from rattling against the drywall. And--thanks for the picture, they are valuable on this site. David
Old 12-17-2009, 08:06 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... Looks like an old felt cold weather boot liner...
Old 12-18-2009, 01:26 AM   #4
Thanks much, We just moved in and I am looking forward to a lot of DIY but then these little things pop up and I wonder if its worth it.
Tags
in-wall asbestos
Botched asbestos removal in home... runfrombears General Discussion 28 07-31-2012 10:21 PM
building a wall against an exterior wall Mike L General Discussion 2 08-20-2009 03:50 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
