Asbestos Ducting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 12:06 PM   #1
Asbestos ducting
Can asbestos wrapped rigid ducting be safely cleaned in California?
Kleenair is offline   Reply With Quote
Old 04-17-2012, 12:16 PM   #2
MarginallyQualified
Rewards Points: 2,464
By "rigid" I'll assume that you mean standard sheet metal that has had asbestos smeared onto the OUTSIDE at the joints (and maybe more). OK?
If so... and if you DON'T DISTURB the asbestos you'll be fine.
The one thing to do though is add another coat of duct sealing mastic that will ENCAPSULATE the asbestos. You can get it anywhere.
As to cleaning the INSIDE of these sheetmetal ducts... sure.
hth
Old 04-17-2012, 12:17 PM   #3
Rewards Points: 12,878
Are you 100% sure it is asbestos?
Has it been wraped or coated to seal it?
Old 04-17-2012, 12:29 PM   #4
Yes it is wrapped with a white card board looking material that I'm told is asbestos
Old 04-17-2012, 12:39 PM   #5
How old is this house?
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Can someone help me identify if these wall sidings are ASBESTOS? LynniieRockz Safety 15 12-01-2011 11:33 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-17-2010 12:28 AM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 11:49 AM
