Asbestos??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 11:31 AM   #1
hohadcr's Avatar
Rewards Points: 306
Asbestos???
Need to add Hvacs to two bedrooms, need to add the duct work through the attic. I took pic of the insulation of the attic. Do you think it is asbestos insulation?
This house was built in 1950.
hohadcr is offline   Reply With Quote
Old 07-16-2012, 11:56 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
It looks awfully suspicious. I would get it tested before you stir around in it.
Old 07-16-2012, 11:59 AM   #3
Looks like cellulose to me. Post a closer in pic.
But bottom line is you'll only get an educated guess here. The only way you will know for sure is get it tested.
Evstarr is offline   Reply With Quote
Old 07-16-2012, 03:09 PM   #4
hohadcr's Avatar
Rewards Points: 306
mmm educated guess would be very helpful ... thanx everyone!!
Old 07-16-2012, 06:36 PM   #5
Civil Engineer
Rewards Points: 4,514
I don't follow. What possible use would an educated guess be to you? Many products from 1950 contained asbestos, many did not. It is impossible to determine if a given product contains asbestos without a laboratory test, regardless of how educated you are.
Old 07-16-2012, 09:37 PM   #6
Agreed. There are many labs that will test a sample for less than $30.
Matt Kiefer
Columbus Advanced Inspections
Columbus Ohio Home Inspections
mkiefer is offline   Reply With Quote
Old 07-17-2012, 11:01 PM   #7
hohadcr's Avatar
Rewards Points: 306
thanks guys. I got it.
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
ASBESTOS..... lots of questions. Dyoung Building & Construction 22 02-14-2012 06:15 PM
Asbestos in old vinyl floor taubel Flooring 3 08-19-2010 09:48 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-17-2010 12:28 AM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 11:49 AM
