Armstrong Tegular Edge Not White, What To Do - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 04:56 PM   #1
Rewards Points: 640
Armstrong Tegular edge not white, what to do
I have Armstrong 271 (I think) tegular panels that are 2x2, the edge you cut and cut back to create the reveal is not white, it is grey... so if you see where the cute was made against a wall it shows as grey..
what do you do about this? any kind of paint or anything that matches to make it all white?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 05-13-2013, 06:09 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
nothing I'v found will cover it? everything soaks in leaving grey behind. you might try sealing it then paint?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 05-14-2013, 07:40 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
From Armstrong's install manual:
Armstrong Touch-up Paint #5761. One 32 oz. bottle of touch-up paint will coat 200-250 lineal feet of tegular edge on Ultima (mineral fiber board).
Cuts made against a wall are not usually painted since they can't be seen.
Here's a link:
http://www.armstrong.com/common/c200...iles/46359.pdf
Old 05-16-2013, 11:24 AM   #4
Rewards Points: 640
Here's a link:
wow I almost had a heart attack when I saw the price, 8 oz costs $102 at lowes!!!!
http://www.lowes.com/pd_89091-61-576...aint&facetInfo=
Old 05-19-2013, 11:19 PM   #5
scribe cuts on a reveal tile are never painted. If you are that concerned about them, you can raise your grid 3/8'' and get small blocksto sit on your wall mold to raise your t's so you do not need to scribe your tiles.
ubcguy89 is offline   Reply With Quote
Adding drip edge to low-pitch patio roof Joboo Roofing/Siding 13 08-07-2016 08:35 PM
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
White distressed furnitures in a Mid Century? SBLima Interior Decorating 2 06-23-2012 10:11 PM
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
Re-painting a textured wall a darker color, (currently white) that meets a textured ceiling (white). mcarter Painting 2 10-24-2010 09:22 PM
