Arguement Over Faux Stone On A Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 10:29 PM   #1
Arguement over faux stone on a fireplace
I was wondering what opinions are on fake stone on a fire place. My friends and I seem to have different ideas on how it should be done.
My idea (with help from reading old threads)-Durarock screwed on with correct screws,lathe, scratch coat then stone
Friend #1-durarock screwed on, stone put dirrectly on board
Friend#2-Drywall,stone put on with mastic.
Friend #3-Dry wall with lathe, scratch coat,stone. His other idea was 1/2 inch plywood instead of drywall.
Just wanting some replies on the correct way. Ive been given good info on here on how to do my shower so i trust the opinions i get. Thanks
viper1 is offline   Reply With Quote
Old 01-04-2010, 12:17 AM   #2
Rewards Points: 410
Well hope you don't mind me butting in ,that makes two of us that are confused on this.
I want to do a half exposure wall in the basement in this rock( its framed out with 1" foam then frame).
I've looked at 2 companies Cast Natural Stone (menards sells it) and Canyon rock (home depot).
'Cast' mentions cement board as a option for interior 'Canyon' does not.
I'm leaning toward 'Canyon' and believe that cement board would be the best backer even though it(Canyon) makes no mention of it.
Both say board, building paper,lath, scratch coat, then butter and place stones.
Would you still need to use paper if you used cement board?
High Gear is offline   Reply With Quote
Old 01-04-2010, 07:39 AM   #3
Rewards Points: 95
What will you be going over? Is the fireplace brick now? If so you do not need to put any substrate up. Adhere the stone directly to the brick with thinset. If you need a substrate use a concrete backer board such as durarock. Then attach stone with thinset.
No paper. Hang the concrete backer board. Adhere stone with thinset.
NJ Brickie is offline   Reply With Quote
Old 01-04-2010, 08:27 AM   #4
Rewards Points: 1,222
Hardie backer and thinset over sheetrock, thinset over clean brick.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-04-2010, 10:13 AM   #5
Rewards Points: 410
Do I understand right, that with cement board no paper, lath & scratch coat is needed?
Old 01-04-2010, 10:52 AM   #6
joed's Avatar
Rewards Points: 11,990
Follow manufactures instructions. I would imagine some is thicker and heavier than others and would require a different technique.
Old 01-04-2010, 02:22 PM   #7
Rewards Points: 95
Yes, with concrete backer board no paper,lath, or scratch coat is needed. Apply the stone directly to the CBB with thinset.
Old 01-04-2010, 02:25 PM   #8
Rewards Points: 95
For interior applications of cultured stone, thinset applied directly to a suitable substrate is IMO the best practice.
Old 01-05-2010, 09:07 PM   #9
So CCB over the framing and thinset the stone on. Any suggestios on screw spacing?
Old 01-05-2010, 11:28 PM   #10
Concrete & Masonry
Rewards Points: 526
My personal preferance is #3, but #1 is acceptable as well IMO. The only time I use #1 is under thin brick as they lay better on the flatter surface.
jomama45 is online now   Reply With Quote
Old 01-06-2010, 04:45 PM   #11
Rewards Points: 95
Viper- Follow the manufactures specs for screw spacing. I use Hardi backer and the spacing is 6" OC.
Old 01-06-2010, 06:05 PM   #12
Rewards Points: 410
Thanks guys..... Oh BTW I've been e-mailing Canyon stone (GAF) to see if
CBB was acceptable or left out of the literature for a reason.
I finally got my answer after 2 emails
CBB is acceptable as long as you use the rough side. For example, DuRock products have a smooth and rough side
Regards,
J.D. Taliaferro
GAF Technical Services
1-800-ROOF-411, Option 1
Old 01-06-2010, 09:02 PM   #13
thanks everyone great info. Sucks I was wrong,lol.
Old 01-07-2010, 04:52 PM   #14
Rewards Points: 410
Only suxs if you do it wrong and have to redo it.
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 05:58 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 06:38 AM
using faux stone on interior walls...? DIY4EVER Building & Construction 21 12-21-2007 10:43 AM
