Arched Niches - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2008, 12:08 PM   #1
arched niches
I am hoping to build a couple of small arched niches by removing the outer drywall between the studs and retaining the back drywall as the back wall of the niche. I would drywall the sides and the under part of the arch.
My question is: How should I tape the inside corner of the under part of the arch where the new drywall will meet the old drywall? The sides would be a straightforward inside corner tape job, but the arch inside corner would present a problem since the tape would end up overlapping on itself as it follows the curve of the arch. Any suggestions?
Thanks.
billyg is offline   Reply With Quote
Old 04-06-2008, 08:14 PM   #2
niche
check at your local drywall supplier. there are many corner beads made to do what you want.
jason h is offline   Reply With Quote
Old 04-06-2008, 09:00 PM   #3
Thanks.
Not arched but ... for mine I did not use drywall as the sides or for anything. Mine has wood as the framing and 1/4" masonite as the back panel. It was much easier to build as you could make it in your shop and simply cut drywall, insert and caulk.
raam is offline   Reply With Quote
Old 04-07-2008, 09:43 AM   #4
Rewards Points: 1,274
Christ! The mouldings cost more than the object d' art!
LawnGuyLandSparky is offline   Reply With Quote
Mudding a Arched Doorway Livens Building & Construction 4 03-14-2008 03:25 PM
arched opening ITE Remodeling 5 12-09-2005 05:14 PM
