Old 12-15-2012, 08:00 AM   #1
Aquarium stand for basement bar
Hello,
I am building a bar immunity basement which will feature a 300 gallon aquarium. I plan on building the aquarium stand out of LVL lumber. My question is: will Lvl lumber be ok if it's right against concrete or should I build a green treat base such as 2x6 or plywood?
Thanks!
bthom2 is offline   Reply With Quote
Old 12-15-2012, 08:36 AM   #2
I would use a natural type wood. I would be afraid that lvl or plywood would react to something in the tank. Maybe I just do not like those type of engineered types of wood.
paintdrying is offline   Reply With Quote
Old 12-15-2012, 08:48 AM   #3
Unless the LVL chemicals magically find a way to travel through thick glass, I'm not too concerned with that aspect.
Old 12-15-2012, 09:18 AM   #4
If it's going to be in direct contact with the slab then use pressure treated or a foam sill under it.
Wall mounted shelving for aquarium thefixerupper Building & Construction 1 02-12-2012 07:14 PM
Framing for 3000lbs+ Aquarium bioload Building & Construction 12 09-13-2011 10:35 PM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 03:47 PM
GFCI for wall mounted aquarium LOST VEGAS Electrical 4 04-19-2010 07:58 PM
Strengthen floor for aquarium theboomboomcars Flooring 11 05-21-2008 09:34 AM
