Old 04-13-2009, 10:03 PM   #1
Question Apply stone verneer over sealed concrete ?
I want to install man made stone verneer ( a concrete product) which is approximately 1.5 inches thick, on a poured concrete wall that has been damp-proofed with a tar type sealer. How do I insure that the mortar/adhesive will adhere to the sealed wall? Will the mortar/adhesice stick to the tar? Do I have to apply a metal lathe with some type of concrete anchors?
Roy Rowlett is offline   Reply With Quote
Old 04-14-2009, 12:21 AM   #2
Concrete & Masonry
No, the mortar will not stick to tar. I would suggest you get the grinder out with a diamond (or carberendum) wheel. After you clean that off, I would suggest you apply a slurry coat of bonding agent & cement.
jomama45 is offline   Reply With Quote
Old 04-14-2009, 08:50 AM   #3
Or just lath it.
It ain't Rocket science unless you are building rockets
Tscarborough is offline   Reply With Quote
Old 04-14-2009, 09:47 AM   #4
Structural Engineer
Originally Posted by Tscarborough View Post
Or just lath it.
This, especially if above grade you'll need a gap between the veneer at the wall and weep holes at the bottom to allow moisture to get out. This will also need proper flashing detail.
wildcat is offline   Reply With Quote
Old 04-14-2009, 10:35 AM   #5
Thumbs up I have another idea.
I want to install man made stone verneer ( a concrete product) which is approximately 1.5 inches thick, on a poured concrete wall that has been damp-proofed with a tar type sealer. How do I insure that the mortar/adhesive will adhere to the sealed wall? Will the mortar/adhesive stick to the tar? Do I have to apply a metal lathe with some type of concrete anchors?
This is a basement wall that I waterproofed. I put the tar up too high above grade, onto the part that I want to install the verneer on.
Instead of grinding or lathing, perhaps I could sand blast it off. That seems easier to me.
Since it cleans up with mineral spirits, maybe I can loosen it with mineral spirits, or muratic acid, then pressure wash it off. Then I could etch it with the muratic acid. That seems like it would make the surface able to hold the mortar/adhesive.
Any thoughts on this?
Old 04-14-2009, 11:53 AM   #6
not sure how much s/b'ing you've done but, it it were mine, i sure as **** wouldn't - 1st place, you'll need, at least, 100sfm @ 90psi out of a 1/8" nozzle to get any decent work,,, next, the asphalt cement ( tar ) will act as a 'resist' 'cept the thin spots'll blow off quick & you'll get a dimple'd surface,,, the cement'll also melt from the sand's friction & make a larger mess,,, neighbors'll also complain about the dust.
here's my method - 20# propane tank, weedburner torch, & ice scraper - soften the coating & scrape off,,, next apply s/s expand'd metal lath & mortar your rocks to it.
yesitsconcrete is offline   Reply With Quote
Old 04-14-2009, 02:37 PM   #7
I've never seen a cultured stone application with an air space and weep holes.
NJ Brickie is offline   Reply With Quote
Old 04-14-2009, 03:02 PM   #8
Default Not a retaining wall
I think he thought it was a retaining wall. That is why I clarified my question after his comment. I think I am going to try loosening the tar with a solvent, then pressure wash it.
Old 04-14-2009, 04:12 PM   #9
lest anyone think my earlier suggestion was ' pie-in-the-sky ', resolving problems of this sort are normal prior to completing our work,,, this method isn't just flip of the coin but, rather, 1 that's adopted in the applied decorative concrete craft after trying all the other jack-leg approach's.
obviously you don't have to make a profit on work at your home NOR are you burden'd w/regards for environmental damage but those rqmts govern us,,, p/w'ing won't do squat imn-s-hfo ! ! !
Old 04-14-2009, 07:51 PM   #10
The trend is to put drainage behind adhered veneer. It is not one that I necessarily agree with, but that is one system of doing it. The cause is that just like with any other tried and true system, people take short cuts, that causes problems, and a new method is devised to "fix" doing it the wrong way (and provide for some profit opportunities along the way).
What I mean:
The proper wall system for adhered veneer should be exactly the same as for 3 coat cementious stucco, with the stone replacing the final coat:
Proper wall makeup:
backup wall:2 layes of waterproofing material:lathing:scratchcoat:browncoat:finishcoat/veneer stone
Normal adhered veneer stone application:
Backup wall:1 layer of waterproofing material:lathing:scratchcoat:finishcoat/veneer stone (and some people wetset the stone dierectly into the scratchcoat, further devolving the system.
If done properly, there is no need for the wall to be weeped. Done as the new "normal" method, you better weep it, and hope for the best anyway.
This poster's wall is different, though, and the waterproofing should be left in place, lath attached, a scratchcoat applied and the then stone adhered to that.
Old 04-14-2009, 07:56 PM   #11
Unhappy
The trend is to put drainage behind adhered veneer. It is not one that I necessarily agree with, but that is one system of doing it. The cause is that just like with any other tried and true system, people take short cuts, that causes problems, and a new method is devised to "fix" doing it the wrong way (and provide for some profit opportunities along the way) of applying the wall system.
What I mean:
Proper wall makeup:
Thank you all for your professional recommendations.
As a non-professional, I need some guidance as to how to attach lath to a poured concrete wall.
Old 04-14-2009, 08:04 PM   #12
Hilti gun and washers.
Tags
concrete, sealed, stone, tar, verneer
More On This Topic
A stone cap can improve the appearance of a stone wall, as well as its stability. By choosing stones based upon their flatness, size and ability to fit tightly on top of existing walls, you can create an attractive, yet safe, structure that will maintain... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. As an inspector and I inspect a lot of these homes and check them to make sure that our... Read More »
Decorate your dollhouse just like you would decorate your real fantasy house. You can let your imagination run wild, without the worry of functional details or comfort of the occupants. The only guidelines to follow when decorating a dollhouse are to... Read More »
Discover how to write "weep" in Chinese characters in this free video on Chinese words containing the "Shui" (water) character. Read More »
By simply adding personalized buffet markers to your buffet table, you take the guesswork out of what you are serving and where everything goes. Here's how to add these convenient helpers to your table. Read More »
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 01:44 PM
Help: Installing Faux stone over interior concrete surface cips General Discussion 20 05-31-2009 07:10 PM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 33 03-08-2009 10:30 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 06:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
