-   -   apply masonry waterproofer to wood stud? (http://www.diychatroom.com/f19/apply-masonry-waterproofer-wood-stud-144627/)
anuvanoob 05-23-2012 12:10 PM
I'm constructing an accent wall and the bottom/sill plate of it's framing will need to be fastened to the concrete basement floor. Being that that area of the basement sometimes gets wet during heavy rain I figured the bottom plate needs to be waterproofed. The associates at Lowe's told me to apply Drylok's masonry waterproofer to the stud and that'll protect it.
While applying the Drylok to the bottom plate stud last night I couldn't help but think this method was wrong and backwards. Is this indeed a wrong way of waterproofing the bottom plate? If so, what are some right ways to protect the frame from rotting?
Thanks in advance
kwikfishron 05-23-2012 12:28 PM
199 Attachment(s)
Pressure treated lumber is what you use against concrete.
I guess the guy at Lowes hasn't worked in that part of the store yet. :laughing:
anuvanoob 05-23-2012 12:47 PM
Well, we discussed that and it was nixed immediately. Pressure treated lumber appears to be a personal no-no for most folks for projects inside the house because of the potentially dangerous stuff its made up of. I don't want it in my house either.
kwikfishron 05-23-2012 01:01 PM
199 Attachment(s)
Well then roll out some sill seal.
anuvanoob 05-23-2012 01:08 PM
Better than Drylok? If so, how do I apply it?
kwikfishron 05-23-2012 01:17 PM
199 Attachment(s)
It's foam, it comes it a roll (Google it).
It will create a break between the concrete and the wood, you could use asphalt roofing to create the break too.
In all my years never heard anyone using Drylock that way. :wink:
anuvanoob 05-23-2012 02:01 PM
ah, I see. That looks a hell of a quicker than coat -> wait 3 hours -> coat again -> wait 3 hours. Thanks!
One last question: I'm using reclaimed wood flooring as the wall and the bottom row will touching the concrete basement floor... how do I protect that bottom row from rotting too?
concretemasonry 05-23-2012 02:14 PM
Drylock was never intended to be used to protect wood from moisture. The sweet talking, helpful guy at the big box did not know what he was doing. Drylock is just a heavy paint really and is meant for concrete waterproofing and not to resist vapor transmission.
The sill seal is a good suggestion and I have even seen a strip of felt, a strip heavy poly and another strip of felt, which works well also. A layer of poly does not work because it is not tough enough to resist adrasion and perforations.
Dick
kwikfishron 05-23-2012 02:19 PM
199 Attachment(s)
I'd start a new thread in the flooring forum of this site with that question. :thumbsup:
anuvanoob 05-23-2012 03:00 PM
What about staining the bottom plate stud like you would for your deck? Will that protect against rotting?
ratherbefishing 05-23-2012 03:26 PM
"....that area of the basement sometimes gets wet during heavy rain....reclaimed wood flooring as the wall and the bottom row will touching the concrete basement floor... "
How wet? Are we talking kinda damp? Or standing water? If it just gets damp, I'd use PT for the bottom plate, with sill seal between it and the floor. If there's an inch or so of standing water, then you may need to rethink the project. In either case, I don't think running the reclaimed wood all the way to the floor is a great idea. If the floor just gets damp, maybe a 3/4" or so gap. If you get standing water, some type of water-resistant baseboard, (fiberglass, plastic?) might be a good idea. But even a PT bottom plate may not keep the bottom ends of the studs from rotting.
I can understand not wanting a lot of PT lumber inside living quarters. But I think one piece for the bottom plate is the better idea.
anuvanoob 05-23-2012 03:34 PM
Yes, it just gets damp, there's no standing water. If there's another design or layout for the bottom row of the paneling I'm open to it. I figured the bottom row should touch the concrete floor to hide the bottom plate of the framing and it's sill seal.
