Apartment Garage Breaker Upgrade - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2009, 02:07 AM   #1
Apartment garage breaker upgrade
I'm curious if anyone knows what code is for Apartment garages. We're considering upgrading the breaker for our workshops which are out of a few of the garage bays located on the property.
I'm located in Colorado. We have an air compressor that keeps tripping the breaker. I'm assuming its a 15A. We were considering going to a 20A. Wanted some professional opinions.
1gcrazy is offline   Reply With Quote
Old 06-30-2009, 05:47 AM   #2
Changing a breaker to 20A requires replacing the wire from #14 to #12. You can't just swap breakers. And most tenants are not allowed to make such changes without owner approval.
Old 06-30-2009, 05:54 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I don't understand the question. I would call the local building department
The Amp rating of a CB is on the handle. It should say '15' or '20'
I am not a professional, this is a DIY forum and a lot of professionals are on it.
In general since a 20A breaker is rated to carry a larger current than a 15A breaker then larger wire is also required. 14AWG for 15 Amps and 12AWG for 20 Amps. Call the local Building Dept for the requirements for how to get this done.
Welcome to the forum and Good Luck
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-30-2009, 08:48 AM   #4
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
1 G crazy,
Yes, i echo what Just Bill and PaliBob said about the 12g with a 20a breaker. You might be lucky however chances are you won't be, lol. The wire that is tied to that 15a breaker MIGHT and I say MIGHT be 12ga already but it is more than likely 14ga. wire.
You could call an electrician and they can come out and tell you whether or not you can change the breaker or not. It is just a matter of calling in the professionals that are trained in the electrical field.
Good luck and be safe!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Upgrade to garage joists kirkl General DIY Discussions 2 05-19-2009 12:26 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 04:36 PM
Firerating an apartment over a garage Jim64conv Building & Construction 3 07-21-2008 09:15 PM
Breaker Panel In Detach Garage Jamn68j Electrical 2 04-25-2007 03:30 PM
Garage Apartment LoriMD Remodeling 1 01-17-2007 08:30 PM
