Apartment Floor Mess- Pouring Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 11:11 PM   #1
Apartment floor mess- pouring concrete
Hey guys, newbie on the forum, just a quick question for those of you with a few years on me.
I'm renovating a friends kitchen and bathroom in a first floor apartment. I started removing the bath floortile today when I realized there is no real subfloor, just cemented beer bottles with broken tile and 10" of thinset to make the shower base.
I removed most of it and am now left with broken up cement/thinset/tile with solid concrete in some places.
I'm going to be putting down porcelain tile, so my two choices are:
Frame a wood subfloor, put down plywood, put down cement board, thinset tile.
OR
level out, Pour a concrete slab with a broom finish and thinset the tile to that.
I'm leaning for the latter, as it's less work, easier and would make more sense I think.
Comments?
If I go with the slab, will portland/ sand/ water work or should I use a latex additive?
There is a basement below so moisture is not a big concern (at least i don't think)
Any thickness recommendations? There is a cement base in some places so I shouldn't have to go too thick, right?
Thanks for any help guys,
W
wjplata is offline   Reply With Quote
Old 07-10-2012, 11:13 PM   #2
liscenced electrician
Rewards Points: 538
You opened up a big can of worms. i think pouring concrete is your only real option. But you need to take down all the wood framing first.
jimmy21 is offline   Reply With Quote
Old 07-10-2012, 11:19 PM   #3
My other only option was to put down a third layer of tile over tile that was cracking/ falling apart over a subfloor that was never done properly in the first place.
wood framing only goes a foot into the bathroom (extends out from the hallway) not a big problem
Also think a wire mesh would be a good idea in the concrete, correct?
pouring concrete imogene40 Building & Construction 13 01-16-2012 06:08 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Crack in concrete 2 days after pouring? danreg99 General DIY Discussions 19 10-14-2010 10:00 AM
pouring concrete over asphalt cstarkey Building & Construction 12 08-23-2009 07:14 AM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
