Anyone Heard Of Enviroguard Or Windsor Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 11:08 AM   #1
Anyone heard of Enviroguard or Windsor windows?
Need to find out about these windows. I am still window shopping and thought I had it narrowed down to Marvin, Anderson & Eagle. I know Eagle is owned by Anderson, but I am looking at their line as well. The problem is I went back and looked at what the contractor had proposed and these were the 2 companies he offered up. So I am trying to find anyone who might know something or had worked with either of these products and what kind of feed back you had on them. Thanks.
Hoyacoach is offline   Reply With Quote
Old 07-31-2008, 10:59 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I haven't seen there product up north here. can't help. I believe they target your climate zone. BOB
Old 08-01-2008, 08:40 AM   #3
I have seen Windsor and even bought one ( should have taken it back it didnt match the other windows) It seams to be very simular to an Anderson
clasact is offline   Reply With Quote
Old 08-01-2008, 12:57 PM   #4
747
registered
747's Avatar
Rewards Points: 534
Marvin is the way to go. Thats a cadillac there Anybody tells you there not there full of crap. Concerning the windows he wants to go with. Maybe thats what his supply house offers. But that doesn't mean you have to go with that. Its your house and you have the final say so. I also like pella's aritectual (spelling) series. Your in a hot weather climate would recomend getting argon filled windows. Which is a gas that stops the heat from coming through in the summer. Its also works on a reverse principle for the winter to make the house warmer. When looking at the marvins your wide open on those. They come with anything you want between the glass for efficency.. Example low e, argon filled, etc. Have the salesperson explain every option available between the glass for energy efficency. As stated about i also like the pella aritectual series once again your wide open there between the glass. I also like pella's designer series. There the ones where you can get window coverings which can be replaced easily if you should decided to update your decor or shades mounted between the glass. You have the option shades or coverings. Which in a hot weather climate might not be a bad ideal.
747 is offline   Reply With Quote
Has anyone heard of GlowCore? bwoo HVAC 16 02-17-2009 10:26 AM
Has anyone heard of "Final Fusion Finish" siding? ext237 Building & Construction 1 06-23-2008 04:15 PM
Heard bad advise today. Hamilton Painting 24 05-27-2007 10:56 AM
Has anyone heard of StyroTrim? VanessaHoward Remodeling 1 02-15-2007 08:33 PM
