Anyone Have Luck Jacking Up House And Putting In A New Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2008, 11:54 AM   #1
anyone have luck jacking up house and putting in a new basement?
our current basement is terrible. it floods during heavy rain and was put in too deep to positive grade. We plan to tile/waterproof the best we can but we are on flat land and can't grade so as a last resort we are looking at having someone jack up the house and tear out the old and put in new. I would love to hear anyone's experiences doing this or if you know of someone who did it how it went. Thanks!
annie68164 is offline   Reply With Quote
Old 06-15-2008, 12:00 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I have seen it done several times and they all seem to appear successful.
I would be cautious that the contractor hired to do this is experineced. Jacking improperly can cause a lot of damage and when excavating or filling, compaction is critical and lack of proper fill and compaction can cause a great deal of future problems and damage.
Old 06-15-2008, 12:25 PM   #3
Advice worth 2 cents!
Rewards Points: 150
I moved my home 75'.
It's a really easy job but, you need a lot of wood blocks, 2 steel girders, 4 hydraulic jacks and 1 hydraulic pump.
Why can't you fix the basement you got? Believe me, if you raise the house your going to break a lot more stuff!
Rent a backhoe and dig the entire perimeter. Lay some crushed stone and re-do the drain. Install a membrane on the outside wall then back fill with quality material (man made).
After I did mine I shot 3" of urethane foam on the inside walls.
- pete
---pete
HandyPete is offline   Reply With Quote
Old 06-15-2008, 02:41 PM   #4
Wink
there are so many options- you are right...
we're considering several ideas. first we plan to try to cheapest route which is Tim Carter's idea of trenching 2'x2'x6" around the house and laying tile/gravel to route the water away from the house. That should cost less than about $500. I figure try that first if it doesn't work we'll see about other options. Just hate to spend thousands and have it end up flooding again in a few years. Thanks for the inputs everyone! It helps to hear people's opinions/ideas.
Old 06-15-2008, 08:38 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
If the foundation is sound and not failing it does not make sense to raise the house and rip the existing foundation out and install new.
I have raised five houses in my time and the aveage cost is around 10,000 plus you have to consider the cost of removing and replacing the foundation. It would make more sense to treat the problem from the outside as stated above. BOB
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 05:30 PM
Old wooden supports in basement of 2 family 100+ year old house ytorrie Building & Construction 2 06-03-2008 07:31 PM
Help!!! Drainage problem flooding basement charlton7 Landscaping & Lawn Care 2 04-12-2008 11:13 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
