-   -   Anyone have any luck using compacted crushed stone to set a fence post? (http://www.diychatroom.com/f19/anyone-have-any-luck-using-compacted-crushed-stone-set-fence-post-121049/)
nullqwerty 10-23-2011 05:15 PM
Hey folks,
I live in Massachusetts and I'm putting in a privacy vinyl fence 6' tall (5' + 1' topper) in some sections and 8' tall in others (7' + 1' topper). I've dug my holes 3' deep 1' wide for the 6' tall sections and 4' deep for the 8' tall sections.
I had been planning to use concrete to set the posts in place but I've heard about some people using crushed stone instead (or Crusher Run) and tamping it down in 6" intervals. This appeals to me because the fence runs along my property line, and the ground drops significantly to the neighbors side (to clarify, the fence is level, but the ground running parallel to it drops off by 3'-5'). The fence is 1'-3' away from the drop off. Because of this I think I could be more prone to movement so my thoughts are that if I used Crusher Run, fixing any movement that occurs will be a lot easier than if I used Concrete.
My concern is the compacted stone might be too weak compared to concrete and movement could possibly be guaranteed within 5 years? True? False? Has anyone had any experience using compacted crushed stone for setting fence posts? Were you successful or did it fail?
NancyNGA 10-23-2011 08:39 PM
What I would be concerned about is that water would seep down through the tiny gaps in the crusher run fill, so the water might stay around the post and keep it wet all the time. Never tried it, though.
hayewe farm 10-23-2011 10:22 PM
I would use concrete, there is a tremendous amount of wind shear on a privacy fence.
gregzoll 10-23-2011 11:31 PM
Wasn't the answer over at http://www.dslreports.com/forum/r264...r-Fence-Posts- good enough, or just needing more of the same answers?
The short is, if this is a temporary, use the stone dust. If making permanent, corner posts and gate posts go in concrete, the rest go right into the dirt.
nullqwerty 10-25-2011 12:35 PM
No it wasn't. I was looking for more opinions and hoping to find people that have used it in the past.
That's why my last post on that forum said:
"I might try to post to one more forum and see if I can find some people that have tried it and had luck with it, or failure. Thanks everyone"
Ron6519 10-25-2011 01:57 PM
I used angular crushed stone O my brother's fence 5 years ago. Cedar posts set in dirt rotted within 4 years. I put pressure treated posts in surrounded by gravel and it's still solid.
Posts were set 36" down over 6" of the gravel. Gravel added in 6-8" lifts and compacted up to ground level.
nullqwerty 10-25-2011 04:48 PM
Cool! Thanks. If you don't mind me asking, was this a privacy fence?
Ron6519 10-25-2011 08:21 PM
Yes, it was a 6 ft high cedar privacy fence.
