Anyone Built A Wooden Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2014, 06:41 PM   #1
Rewards Points: 322
Anyone built a wooden basement?
For a little place in central Texas country I would like a 10x20x8 DIY cellar, walls made of wood. I'd connect it to the house via stairway, probably build a workshop or greenhouse on top of it.
If I used those concrete pyramid shaped supports at the big box for the walls I wouldn't have to mix any concrete at all. I would like to leave the floor plain dirt, or maybe wood, as its primary use will be food storage if I can get some ventilation in there. Wonder if anyone has some building ideas that would help this project get legs.
putts
puttster is offline   Reply With Quote
Old 02-21-2014, 07:16 PM   #2
joed's Avatar
Rewards Points: 12,918
Been done before. You will need a floor to keep the walls from pushing inward.
http://www.canply.org/english/products/pwf.htm
Old 02-21-2014, 09:47 PM   #3
Rewards Points: 322
Would 4x4s laid between the concrete post supports do the job? Upon reflection, I guess I'd need to put some in to protect the other two sides, as well. The floor might be tricky.
Old 02-22-2014, 08:07 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,.... At a Minimum, I'd think ya need a poured footer to build off from,...
Yer precast concrete fence post bases, Ain't gonna work,...
Old 02-22-2014, 09:08 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
do a search for permanent wood foundation.. their more common up north where conditions make it too cold to place concrete
woodworkbykirk is offline   Reply With Quote
Old 02-22-2014, 09:50 AM   #6
MarginallyQualified
Rewards Points: 2,464
The work and expenses involved aren't much (if any) less than what it would take to build forms for concrete. If you were to rent those forms or to use one of the rigid foam board methods... have you priced it out?
20' +10' x2 x8' high x .75' thick... /27 = 13 yards (+ footing)
Old 02-22-2014, 09:57 AM   #7
Rewards Points: 322
Yeah, I am thinking that now. Besides, I couldn't visualize how the concrete base/cross bracing/ posts /sill plate/studs/header would all come together. Would RR ties do the job? I could just nail the studs directly to them.
puttster
Old 02-22-2014, 10:46 AM   #8
Bondo's Avatar
Ayuh,.... By definition, a Foundation is a solid stable base in which to build yer house on,...
I ain't seein' anything solid, nor stable in yer plans,...
Old 02-22-2014, 01:25 PM   #9
Rewards Points: 3,630
Here's a link you can take a look at, the exterior foundation walls I seen were covered with 30# roofing felt b4 backfill.
Canarywood1 is offline   Reply With Quote
Old 02-22-2014, 02:07 PM   #10
Rewards Points: 256
ehhh... I dont know about a wood foundation. Something about that doesnt sit right to me. For this guy it would be alright but a house? not mine. I have replaced enough PT decks to know it doesnt last forever.
JustinK is offline   Reply With Quote
Old 02-22-2014, 02:32 PM   #11
Rewards Points: 322
Looks like you just lay in some gravel, lay 2" sill plates on top of ther gravel, then raise up the walls. No piping for a drain system that I could see, though they do lay poly over the gravel. Then hang floor joists and a floor over that.
A two man job, really. The trickiest part is making sure the sill plates are laid right.
Old 02-22-2014, 03:16 PM   #12
concretemasonry's Avatar
Rewards Points: 2,608
If you insist on a wood foundation that was touted as "The best thing since sliced bread" back in the 1960's and 70's, but the system has become a failure except for short term jobs that can be hidden. The biggest problem is putting wood in the ground along with moisture and soil that is a bad recipe for long life or future value.
Even in the period, they required wood that is not longer available and the foundations were not allowed to be put on concrete footings (2x6 CCA treated wood plates), but had to be placed on gravel beds that were also used for moisture collection. They did require a poured concrete floor to keep the walls from sliding inward.
I always thought it was an ides that came out of bar meeting/argument with members of the wood steel industry regarding foundations/basements. Only one guy tried to really promote a system that has flopped.
Dick
concretemasonry is offline   Reply With Quote
Old 02-22-2014, 05:58 PM   #13
Rewards Points: 322
Ha Ha Concretemasonary, not surprised you are recommending a concrete floor!
Seriously, I am building a root cellar on a plot of land 100 miles from a Home Depot. Looking for practical advice.
Old 02-22-2014, 08:02 PM   #14
Rewards Points: 122
I have been in one wooden basement that had a two story house moved in. All pressure treated and heavy 2x10 wall studs. It was only a few years old and the walls were already bowing inwards to the point that failure was not far in the future.
Don't underestimate the force that the earth will push on those walls! It's a bad idea all around.
York v45 is offline   Reply With Quote
Old 02-22-2014, 10:29 PM   #15
York -
The bowing in of the walls were a common problem with wood basements. You could usually pull a string across a wall at ground level and it was obvious.
It also could be from the bottom plate rotating/tilting or the lack of making a decent rigid connection to the floor system for lateral support.
puttster -
Concrete is the only way to get a decent floor in a below grade space that is touted as being insulated (if the fiberglass does not absorb any moisture). It is cheap and easy - just open a window and pump or dump. the soil under the floor is not that cool.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
septic pump for basement toilet denemante Plumbing 4 02-13-2013 10:42 AM
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 03:11 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
wooden basement post rotten on bottom truckinkat Building & Construction 1 09-29-2008 05:35 AM
