Any1 4 NYS 2007 Code Help? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2007, 09:14 PM   #1
Extreme DIY'r Adk's, NY
Rewards Points: 272
any1 4 NYS 2007 code help?
OK, trying to interpret new 2007 existing building nys codes.
regarding fire rock on wood framed commercial building. confusion on type of use, change of use, compartment size, etc. Building going from a bingo hall with kitchen to a fitness center. Kitchen being removed and replaced with locker rooms/showers. No moisture rock anywhere in the bldg now. I want the new locker rooms to be moisture rock, owner bought 1/2" I think it should be 5/8"
tia
crecore is offline   Reply With Quote
Old 12-03-2007, 03:12 PM   #2
Rewards Points: 5,336
I'm not familiar with the NYS codes, but it seems the commercial space built on LI is 5/8" firecode over steel studs. I do residential remodeling as a living and this is just my observations of commercial space I see being built.
Ron
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
underground code tom b Electrical 8 03-23-2008 10:55 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
