Any Way To Reduce Heat On Bricks? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2008, 10:20 PM   #1
Any way to Reduce Heat on Bricks?
so my bedroom faces east, and when the sun comes up it gets the bricks nice and toasty. this means that my bedroom from like 10-2 is 15 degrees warmer than the rest of the house
is there ANYWAY to reduce the heat coming in from the sun? stupid question i know, but just curious
iminvalid is offline   Reply With Quote
Old 05-18-2008, 10:03 AM   #2
is it the brick is getting hot or to much sun comming in the window that is makeing your room so hot if its the window add a shde or awanning but the brick should be insulated so that really wouldnt make the temp rise to that extent I wouldnt think but I could be wrong
clasact is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
