Any Way To Lengthen A Header? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 11:56 PM   #1
Rewards Points: 1,016
Any way to lengthen a header?
I have two picture windows - each require a 96" wide rough opening.
I have two existing openings, each 94" wide - you see the problem...
The openings are framed with the typical 2x4 king studs, with trimmer studs holding up a doubled 2x8 header.
Exterior is stucco. The wall is carrying the load of the ends of the roof trusses.
Any suggestions on a way to gain a couple inches of opening - other than tearing out the current header and reframing new ones 2 inches wider?
thx!
Vince
Old 01-19-2009, 12:32 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
check out simpson strong tie the might have a header bracket that can help you .You might want to run it past you building inspector
Tom Struble is offline   Reply With Quote
Old 01-19-2009, 01:19 AM   #3
Google found me the Simpson Strong Tie HH4 Header Hanger - may just do the trick by letting me remove the trimmer studs. I'll pass it by the building inspector folks and go from there.
Thanks!
Vince
Old 01-19-2009, 02:15 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
you will still need to remove some of the stucco to fasten the bracket to the header. The bracket is designed to be fastened to both sides of the header.
What i would do is get a long saw zal metal cutting blade (12") and cut the sheathing nails that secure it ( sheathing) to the header. Remove the header and install a new one that will be supported by your Double jack studs. when re-securing the new header to the existing sheathing just use some construction Idahoes and some clamps.
you will need to re frame the jacks and studs so just change the header and be done with it, piece of mind knowing you did it right.
Don't forget to support the the ceiling when you do the change. Good luck BOB.
Old 01-19-2009, 06:53 AM   #5
Remodeling Contractor
A header cannot be extended by code. Inspectors will never pass it. My neighbor had seams not over the post support on a header and the inspector made him rebuild the entire thing.
Old 01-19-2009, 07:00 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks!
Vince
As already stated, you can't "extend" a header. You will be required to "replace" it with a longer header.
- Build Well -
Header in a "modern brace" framed house jtpwils Carpentry 14 11-18-2008 08:24 AM
Header question dc4nomore Building & Construction 35 10-12-2008 05:32 PM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 08:55 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
