Any Warnings For Insulation In A Bathroom? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 08:12 AM   #1
Rewards Points: 156
Any warnings for insulation in a bathroom?
I'm remodeling a bathroom in a 1940's house. I ripped all the plaster out and as usual, there's no insulation. I'm not really too worried about noise but one of the walls in the bathroom is exterior. Standing in the bathroom, I have 2x framing, then 1" plank sheathing, then some kind of old roofing felt, then the exterior wood siding. I was thinking of putting in faced r-13 fiberglass insulation and just stapling the paper to the 2x4's and then covering the wall with a plastic vapor barrier before I apply the tile backerboard. But then I started wondering whether the heat inside the walls would be trapped and possibly create moisture. Since the rest of my house isn't insulated, I could also just say forget it and leave it as is but I like to stick it in there whenever I can. Any ideas?
jayp is offline   Reply With Quote
Old 06-05-2008, 09:00 AM   #2
Registered User
Termite's Avatar
I'd definately install the insulation in the exterior wall. The paper face goes to the conditioned/interior side.
You are also right to install a moisture/vapor barrier on the face of the studs. I wouldn't be too concerned with moisture in the wall. Your old home's walls "breathe" enough that I doubt that will be an issue. You'd run a greater risk of moisture without it!
Old 06-05-2008, 01:40 PM   #3
fiber vs foam
I remodeled 2 bathrooms lately in my house which built 1927.
I used fiberglass in one, and pored in polyurethane in 2nd. Polyurethane won. No headaches with vapor barrier, and R-value is higher (24 for 4"). A bit more expensive and messier, but totally worth is.
photos of smaller bath are attached.
Taty
taty is offline   Reply With Quote
Old 06-05-2008, 01:45 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
If your plan is to use a plastic vapor retarder, then use unfaced fibreglass. You don't want two vapor retarders in the same wall space. If you can't get unfaced, then slash the paper with a utility knife about every 3-4 inches.
Old 06-05-2008, 05:08 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
I agree you don't want two vapor barriers, you will have moisture between the two..
Old 06-05-2008, 06:27 PM   #6
spray on
If you will go with spray on polyurethane, you don't need any additional vapor barrier. It is easy if your walls all striped down to studs.
Old 06-06-2008, 11:08 PM   #7
Knucklez's Avatar
Rewards Points: 930
did you do the spray poly yourself? if so, can you provide more details on this product & process?
Knucklez is offline   Reply With Quote
Old 06-07-2008, 06:44 AM   #8
Rewards Points: 156
yes
I'm going with unfaced due to time constraints! Thanks for the tips
Old 06-08-2008, 10:39 PM   #9
to Knucklez
Yes, I used a Tigerfoam.
http://www.tigerfoam.com/
I used Slow Rise formula, it works well.
Infrared inspection showed significant difference in r-value to compare to fiberglass.
I was poring it into the walls, most of them are stucco from both sides, and I didn't plan to rip them off. It took some time to figure out how it works best, If you need any particular details, like how to make best openings for poring (will be easy to fix them later), how to avoid air pockets, ext, let me know.
Old 08-03-2008, 05:08 PM   #10
Rewards Points: 39
Hi Taty,
In the winter, I can feel a draft where the floor meets the baseboard. Looking behind the air jet tub I see the vapour barrier has not been caulked to the bottom. It is just hanging loose.
How would the slow rise Tigerfoam help. Do you suggest pulling the baseboard and injecting foam to try and seal the leaks.
Thanks,
Art
atw58 is offline   Reply With Quote
Old 08-03-2008, 09:43 PM   #11
Taty is a cutie...do what ever she says....
back in the 70's they tried the visqueen over the faced insul batts..discovered rain pocket...this is a don't do ... even worse in humidity belt down south....keep or allow insulation to have lowest possible RH for most efficient K factor..
Big Bob is offline   Reply With Quote
Old 08-03-2008, 10:35 PM   #12
Rewards Points: 562
ONE tip,,,IF thats an OLD leaky window,,,start there first. Nothing worse than getting all done and finding yourself 'starting over'. if is a pretty new one,your on your way (my pics view fuzzy here)
4just1don is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
Bathroom remodel - need advice sparky472 Remodeling 12 10-22-2007 05:03 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 08:32 AM
