Any Warnings Before Striping Down To The Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 06:08 PM   #1
Exclamation
Any Warnings Before Striping down to the studs?
I am renovating a house that has been abandoned for the last 10 years. I am not a contractor or a builder, kinda a first time do it yourselfer. I got this house for a really good deal but it needs ALOT of work, but I am patient and eager to learn.
Anyway, I want to strip this house down to the studs and start over. I am tearing everything out, bathroom fixtures, cabinets, flooring and all the dry wall.
So my question is, should I have an engineer look at the house BEFORE I pull the dry wall off to look for structural problems, or AFTER (or both)? I would like to save money, but this would cease to be a good investment if the roof caves in on me or something especially if I am crushed to death. But I wouldn't think that sheet rock holds any of the structure together.... but I dont really know, which is why Im asking here
P.S. It’s an octagon shaped house with a Dome Roof if it makes any difference
cadefixedit is offline   Reply With Quote
Old 11-19-2010, 07:34 PM   #2
Rewards Points: 5,336
It would help if you mentioned the reason you think you need to remove the sheetrock.
Before you work on the inside, make sure the house is water tight.
Any issue with the house that you think there are structural problems?
Ron
Old 11-19-2010, 11:32 PM   #3
No major reason, its in REALLY bad shape, probably could repair it, but I have opted to replace it. Looks like the previous owners/tenants went through and threw a baseball every 2 feet around the entire house and ceilings.
Old 11-20-2010, 06:47 AM   #4
The removal will give you an opportunity to check out the true condition of the house and upgrade the electric, plumbing and insulation.
Ron
Old 11-20-2010, 06:57 AM   #5
Tear Out all the drywall, sheet rock
Go ahead and tear it out, it does not help with structural integrity. After you tear out, send the engineer out. Also, you may want to think of treating all the studs at that time. ( Treating with an ANTI-MOLD Liquid, just sprays on) If you want. Then after that I would do A Radiant barrier, Foam Insulation, and another radiant barrier to create a sandwich of ultimate efficiency. What kind of heating and cooling are you going to go with?
ClimateControl is offline   Reply With Quote
Old 11-20-2010, 08:13 AM   #6
I have not decided yet on a heating, cooling system. Im on a raised foundation and the house is 2 floors. Any suggestions? I am putting radiant heat in the bathrooms
Old 11-20-2010, 08:41 AM   #7
Where are you located ?
Are you going to be living in it while renovating ?
Does it need a new roof...windows ?
Old 11-20-2010, 09:08 AM   #8
Live in Northern Cali. It does occasionally snow. I will NOT be living in it.
Old 11-20-2010, 09:09 AM   #9
Probably could use new windows. They are old school single pane
Old 11-20-2010, 09:12 AM   #10
and I'm pretty sure the roof is leaking, duno if it needs a whole new one tho
Old 11-20-2010, 10:26 AM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
It sounds like you are headed in the right direction, but like it has already been said, make sure all your leaks are stopped first.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 11-20-2010, 08:24 PM   #12
Wait what? Fix the leaks first? Why? Wouldn't it be better to fix them after dry wall is off so can see all damage and fix at once? I had planned on having the leaks fixed immediately after demo.....
Old 11-20-2010, 08:45 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
I didn't word that right, you are correct, you do want to gut it first so you can see where the leaks are if any, sorry, I am not good at explaining things sometimes.
Jim
Old 11-20-2010, 09:07 PM   #14
Okay Neat. On the side of safety I actually had a builder/contractor come by and give me an estimate on some work. He assured me the structure was intact and I should be good to take the sheetrock off as long as I dont start knocking beams down with the sledge.
The Following User Says Thank You to cadefixedit For This Useful Post:
BigJim (11-20-2010)
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 03:20 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
