Any Suggestions On Repairing Masonry DIY Style? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 11:49 AM   #1
Any Suggestions on Repairing Masonry DIY Style?
Hi everyone,
So I noticed a 2 cracks in my front facing masonry. Wondering if anyone has any suggestions to product recommendations so I can fix this myself.
Below are some pictures to give you a better idea what I'm dealing with. Any Assistance is greatly appreciated!
Cheers!
earthad1 is offline   Reply With Quote
Old 09-18-2010, 10:31 PM   #2
Bump!
I'd like to perform this tomorrow so any suggestions would be appreciated.
If not, I'm going to plug it with a polyurethane compound that can be used on masonry above the water line (says it accommodates 50% total joint movement.
Old 09-18-2010, 11:10 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, you have a broken brick there so the proper method would be to remove the brick and put in a new one. For any cracks, you would grind out the mortar and tuckpoint the joints.
Old 09-19-2010, 12:07 AM   #4
Rewards Points: 502
I'd let it go as-is. if you absolutly have to fix it, listen to Nap.
honestly, I don't know what you are trying to acomplish with your repair.
forresth is offline   Reply With Quote
Old 09-19-2010, 05:36 AM   #5
Rewards Points: 582
If you cut out the broken brick with a hammer and chisel you will probably lose some of the brickwork above as there is little weight above it. When bricks are lower down the wall it's not a problem to cut it out.
It looks like a typical thermal/moisture expansion/contraction brickwork crack. It's not serious and the soffit is helpng protect the wall from rain ingress.
As nap said if you really want to do the job grind out the joints.
If I was replacing the brick for someone I would expect to take out the cracked section of brickwork and rebuild it as it would be a lot quicker.
stuart45 is offline   Reply With Quote
Old 09-19-2010, 09:26 AM   #6
Thanks for the reply everyone.
The reason I wanted to repair this was I was concerned about condensation or moisture getting in...
So you're thinking I don't need to do anything immediate before winter?
Old 09-19-2010, 01:59 PM   #7
nap
You talking to me?
nap's Avatar
brick fascia, when built properly, is designed to allow for drainage should moisture get behind the brickwork. The wall behind the brick should also be adequately built to be able to withstand moisture as well.
Old 09-19-2010, 11:20 PM   #8
Ok, thanks for all the advice.
I noticed it a few days ago and I'm pretty sure I would have noticed this in the 5 years I've been here, so I'm quite sure its new and it kinda freaked me out (if you look @ my older threads you'll see the "luck" I've had with my home).
Thanks again!
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 03:36 PM
Weatherking drum style furnace with Honeywell s9201a board bobnorman76 HVAC 24 12-18-2010 12:54 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Suggestions for replacing or repairing my porch skiposwald Carpentry 5 09-28-2008 03:25 PM
