Any Reasons I Should NOT Build The Deck Before The Door? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 09:19 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Any reasons I should NOT build the deck before the door?
This is a picture of my backyard. You can see where I have slaved for the past few weeks to get rid of the pachysandra (sp?) that seemed to have ruled the yard before we bought the house.
You can kind of make out the sticks - that's where the deck is going to go. It's going to be somewhere between 22" and 24" off the ground so it'll be an easy walk-out. That big window you see will be replaced by a glass slider eventually.
I'd like to build the deck before putting in the door for various reasons. Mainly because the door is going to involve moving a vent and some other stuff and the deck would get my patio furniture off the lawn and the grill out of my driveway....
Any reasons why I would consider not doing this, or is there not anything wrong with my idea?
CoconutPete is offline   Reply With Quote
Old 07-17-2010, 09:27 PM   #2
Old School
Willie T's Avatar
I'd buid the deck first so I wouldn't have to stand on a ladder to do the door.
Willie T
Old 07-17-2010, 10:44 PM   #3
Registered User
Rewards Points: 5,482
I'd get a permit first and possibly a variance to the neighbor's if that's the dividing fence 3' away.... . The HVAC will be moved only to the dead side of the door, add tile at the entrance to ease any flooring matching/repair problems. Check the window height/width for the new door now.
http://www.lancova.com/deckinfo.pdf
http://www.ci.apple-valley.mn.us/Ins...ck_handout.pdf
Be safe, Gary
Old 07-18-2010, 09:43 AM   #4
firehawkmph's Avatar
Rewards Points: 1,858
Pete,
There's no reason you can't build the deck first. It will be very simple to transfer your finish interior floor height to the outside so you can build your deck at the right height. You could take the bottom couple rows of siding off to attach your ledger and flash it properly.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-18-2010, 10:41 AM   #5
I always like at least a 6" step down from the house to the deck due to snow around here
Old 07-19-2010, 08:15 AM   #6
Rewards Points: 504
I like a small step down as well. A 6" drop would put the walking surface of the patio right in the middle of the second-to-last piece of siding which I think is a good height.
Now onto the 2nd part of the problem ... figuring out how the heck the siding is held on
Old 07-19-2010, 12:01 PM   #7
Registered User
If you do get the snow, go for it! If only for looks, remember if your house joists are 2x6, you may be rotor-hammering through-bolts in the concrete wall now instead of in wood. More money for longer bolts - 8"/4", time and effort. Depends on the joist and beam spans, may have the beams sitting on the pier brackets without posts since working with 22"- a little harder, but do-able.
Interesting parking......
Be safe, Gary
Old 07-19-2010, 12:37 PM   #8
kwikfishron's Avatar
Rewards Points: 368
I think bolting to the foundation would be worth the effort in this case. If for any other reason just to eliminate any potential ledger to wall leak issues.
kwikfishron is offline   Reply With Quote
Old 07-19-2010, 04:05 PM   #9
Registered User
Good point, Ron! That didn't even enter my mind, after you find and fix that problem so many times you don't think it could be done wrong today with all the information available on the web for correct procedure. That would be safer for a DIY'er. Still scratching my head on the Toyota there........
Be safe, Gary
Old 07-19-2010, 04:11 PM   #10
Framing Contractor
If it's done right he won't have leak issues.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-19-2010, 04:17 PM   #11
Framing Contractor
Be safe, Gary
Gary,
Even though he's a DIY'er, he should be doing it right. If he finds out how to do it right first and gets permits and inspections he won't have any problems with leaks. If he doesn't find out how to do it right and get permits and inspections and does have leaks, that's his problems and he gets what he deserves.
Why should he do something that's safer and go into block if he doesn't have to because he might not do the job the right way from the start?
If DIY'ers want to tackle projects, they HAVE to do it the right way just like the professionals like you and me should be doing it.
Joe Carola
Old 07-19-2010, 04:21 PM   #12
Rewards Points: 368
That’s true but there was talk about a step down because of snow buildup.
Old 07-19-2010, 07:24 PM   #13
Registered User
Well, that's what I was talking about also........ Sure is slow tonight, not many posters.......
Be safe, Gary
Old 07-20-2010, 08:33 AM   #14
Rewards Points: 504
LOL. What's so weird about the Toyota there?
It's my wife's car. My car is in the garage (to the left of the toyota) and if we pull her car forward like that we can leave in either car because the driveway narrows as it goes by the house.
Well I'm kinda glad this came up, for some reason I just liked the idea of mounting the ledger into the concrete but I did not tink it was going to be an option since the deck height will be above that, but you are saying that shouldn't be a problem?
Old 07-20-2010, 09:46 AM   #15
Chicago, IL
Michael Thomas's Avatar
In that situation I would install the door, then build free standing deck:
- http://www.deckmagazine.com/article/62.html
and eliminate the ledger attachment and flashing issues entirely
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Possible to build a pergola on top of a deck? nateo Building & Construction 3 04-08-2010 08:46 AM
Entry Door Size han Building & Construction 5 08-20-2009 07:54 AM
Anyone ever build a deck above the outside hatchway? JT Rock General DIY Discussions 2 04-04-2009 01:09 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
