Any Opinions On DYI Polyurethane Injection Kits? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 01:59 PM   #1
Any opinions on DYI polyurethane injection kits?
New poster here.
I have been browsing this site for many months since I started my basement finish project. I am truly impressed with the amount of things I have learned already.
I have 3 vertical cracks in my poured basement walls. I bought the house in July and it was built in 2005. The basement is bone dry and I have not seen any moisture even with the endless rain we had this fall in Michigan.
I am now starting to finish the basement. I had a company quote the polyurethane injection for the cracks and it was very expensive so I looked online and found several DIY port injection kits. I can fix all my cracks for a reasonable price if I do it myself.
There are several companies online selling the kits but they seem to be offering the same product just a different company name selling it.
Do these DIY polyurethane injection work? Has anyone bought and used them with success? If it is worth it I want to seal the cracks for piece of mind before I insulate and drywall.
Rooki is offline   Reply With Quote
Old 01-17-2012, 11:10 AM   #2
Injection Kits
Wow 98 views and no one has used one of these kits?
Old 01-17-2012, 11:53 AM   #3
I think you need to find why the cracks happened. Are you planning an expensive band aid on something that will reappear. I know nothing about this poly injection so I don't know if it can be done effectively from the inside or if you need to excavate and inject from the outside.
mrgins is offline   Reply With Quote
Old 01-17-2012, 12:21 PM   #4
Rewards Points: 672
rim-joist insulation - spray or sheet foam?
Post #9 Homesealed mentions a froth pack. There are plenty of You Tube demonstrations on using these types of kits.
There is a You Tube video demonstrating how to do just about anything.
B
Beepster is offline   Reply With Quote
Old 01-17-2012, 04:02 PM   #5
Concrete & Masonry
Rewards Points: 582
Hopefully "itsreallyconcrete" see's this and can comment, as he certainly has the experience in these kind of repairs........
jomama45 is online now   Reply With Quote
Using Aerosol Polyurethane to finish doors? roxksears General DIY Discussions 4 11-07-2010 05:16 PM
Starter tool kits cellophane Tools 16 10-13-2009 02:58 PM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
looking into dye kits/ bleach repair kits 4 carpets. any suggestions? flooring Flooring 3 09-02-2008 09:21 PM
