Any Joist Hanger Sharper Than 45* Angle Available For Deck? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 09:30 PM   #1
Rewards Points: 43
Any joist hanger sharper than 45* angle available for deck?
For my deck build I need to hang a joist on a sharper angle than 45*, looking at strong tie I don't see anything really available.
Are there other options for hangers, or to securely hanging the joist?
Quicksmoke is offline   Reply With Quote
Old 03-02-2012, 11:14 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They don't make them because you have plenty wood to wood contact, with that angle, for very solid nailing w/o a hanger.
Code approved.
titanoman is offline   Reply With Quote
Old 03-02-2012, 11:26 PM   #3
Rewards Points: 14,312
How do you plan on cutting it?
Why the odd ball angle?
Old 03-02-2012, 11:29 PM   #4
Disabled wood vet
titanoman's Avatar
(messed that up)
Old 03-02-2012, 11:38 PM   #5
http://www.strongtie.com/products/co...rs/L-LS-GA.asp
Old 03-03-2012, 01:01 PM   #6
Rewards Points: 43
I have a driveway that comes off the back of my house next to the sliding door. If you were standing in the sliding door and looking towards the back yard, the driveway goes outward by about 5 ft then angles to the left by about 15ft.
What I'm trying to do is build a deck maximizing the area, that follows the shape of the driveway, so this creates some odd angles.
If I can find a pictuer I took stringing the outline of the deck I'll post it up to give a better idea. I've lost a lot of files lately due to bad hard drives on my laptop.
Old 03-03-2012, 06:26 PM   #7
robertcdf's Avatar
Use the Simpson LS (30,50,70,90) bracket.
robertcdf is offline   Reply With Quote
Old 03-03-2012, 06:55 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
one thing with the ls hangers to take note of,, if you over bend the connector and have to bend it back to the correct angle it becomes weaker and can possilby fail.. make a block that has the correct angle on it.. use the block to prebend the connector to the exact angle
woodworkbykirk is online now   Reply With Quote
Old 03-04-2012, 08:49 PM   #9
Rewards Points: 43
Thank you everyone for all the great info and suggestions!
Joist Hanger Size Question jjandshanon Building & Construction 8 02-05-2012 09:55 PM
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 10:26 AM
Placing joist hanger on top of ledger instead of hangers. hnd83 Landscaping & Lawn Care 1 04-15-2011 08:32 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
