Any Instructions On How To Install Aluminum Porch Enclosure? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2007, 03:45 PM   #1
any instructions on how to install aluminum porch enclosure?
I recently purchased a double door aluminum porch enclosure with side panels. However there is no instructions, I don't know what to start. Is there any instructions available on how to install aluminum porch enclosures?
brisk is offline   Reply With Quote
Old 12-14-2007, 04:44 PM   #2
Remodeler
MinConst's Avatar
What are you talking about? screen walls to enclose an existing porch? Should be fairly easy to figure out. 2x2 alum studs? You need a header and a base plate out of 1x2s then 2x2 uprights on 48" centers.
Maybe with more information we can be more helpful.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 12-14-2007, 06:01 PM   #3
Rewards Points: 5,336
Go back to where you purchased it. They can give you one from another box or make you a copy or they can contact the manufacturer and request a copy from them. Or if the name is on the carton, you can contact them. Do a Web search for the name.
Ron
Need help picking an outdoor enclosure coyote556 Electrical 13 08-06-2007 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
