Any Ideas On Air Condition Vent? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 09:47 PM   #1
any ideas on air condition vent?
by no means am I handy haha I can just do basic stuff. Anyways I removed the ceiling air condition vent so I can paint the ceiling. It seems the sheetrock where the original screws were kind of pulled through to the actual hole.
Upon placing the new bought vent in the store I noticed this. The screws cannot be screwed in. My question is what is the best way to make the holes solid again so I can re-screw. Spackle is not strong enough so I am not sure what to use to fix this. For the time being I used some vinyl adhesive and letting it dry now, but I have a feeling that wont do anything. Any help would be appreciated thanks!
blaqpig is offline   Reply With Quote
Old 06-14-2009, 10:00 PM   #2
One easy way is to drill a couple of holes in the duct to connect short springs, drill corresponding holes in vent cover, stretch spring and connect to cover. Let the springs then pull the cover ups and hold into place.
hayewe farm is offline   Reply With Quote
Old 06-15-2009, 11:28 AM   #3
Registered User
Rewards Points: 5,466
http://www.lowes.com/lowes/lkn?actio...s&N=4294961544
Be safe, G
Old 06-15-2009, 10:27 PM   #4
Hi thanks for the responses!!
What are those screws from lowes? They work in that sense that when a hole is ripped through part of the wall they will still grip and hold in place?
Old 06-16-2009, 04:56 PM   #5
Registered User
It depends on how big the hole for the screw is. If very big, they won't work. Just glue a small block of scrap ply behind each screw hole and fill the wall board with some patch material. Don't slop past the grill outline, let dry, install grill with longer screws. Be safe, G
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
