Any Alternatives To Using Wooden Button Plugs In This Situation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 01:43 PM   #1
Rewards Points: 230
Any alternatives to using wooden button plugs in this situation?
Hi everyone,
I'm planning on redoing the railling in my house with a new cherry wood railing and wrought iron balusters. I have two sections to do, one at the base of the stairs that goes up about six feet, and then another section along the top that's flat and extends for about seven feet. Both sections will utilize a 1x7 piece of cherry wood that will accept the bottoms of the wrought iron spindles. I'm not sure what this piece is called, but I'll refer to it as the "footing piece," like the one in the picture below.
I'll need to stain and polyeurethene the footing pieces, the raillings and the newl posts at some point. Becuase the footing piece for the top section will be boarded by carpet on two sides, I'm thinking that I should attach the newl post to the footing piece, and then stain those pieces prior to intalling them.
If I do this, the only way I can think of assembling everything will be to screw the footing piece with the newl posts attached to the floor and then use those button plugs to cover the holes made by the screws. I don't really like the look of those things, but I cant figure any other way to do it, since I want to stain the footing pieces before I install them.
Any other way to do this?
Thanks,
Kevin
Any alternatives to using wooden button plugs in this situation?-wrought-iron-gates-10.jpg
Ler0y Jenkins is offline   Reply With Quote
Old 02-06-2012, 08:04 PM   #2
Will you be installing new skirt boards as a part of the project? If you are, you could pocket screw from beneath. Are you building your own post or buying a prefab one?
The newel needs to be firmly attached to "big wood" beneath, so I'm thinking just attaching it to the 1x7 won't ride well. If you don't have access below, you can just pocket screw it down and then install cherry base molding around the bottom of the post to hide the holes. I'd pre-finish it and use pins while the glue sets.
RenoStruct is offline   Reply With Quote
Old 02-06-2012, 10:29 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Use finish nails and eagle grip or liquid nails for the sole plate.
They make double-ended lag screws
about 4" long to screw the newels through the sole-plate into the sub-floor.
titanoman is offline   Reply With Quote
Old 02-07-2012, 01:03 PM   #4
Rewards Points: 230
Can I use finishing nails after the finish has been applied? It would seem to me that driving a nail through a board that's been stained and polyeurethened would cause the finish to crack.
Thanks,
Kevin
Old 02-07-2012, 04:30 PM   #5
Disabled wood vet
titanoman's Avatar
Thanks,
Kevin
They won't split anything (#8d).
Use a nail set.
Touch up with putty and urethane.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 11:16 AM
cutting plugs off would violate... Daneel Electrical 9 06-05-2011 05:21 AM
Replacing Wooden RSJ with a metal one? Paul_83uk Building & Construction 7 04-15-2011 08:02 AM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 12:36 PM
