Another Vinyl Siding Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2009, 10:49 AM   #1
Another vinyl siding question
I will begin applying vinyl to my house soon and I plan on also re-sheathing most of it. Most of the current sheathing is that pressed cellulose blackboard ( celotex ) garbage. The house has some older windows I would like to save. What is the best way of removing / replacing the sheathing with out disturbing the windows ? Is it better to cut the celotex out around the brick mold applied to window and refit sheathing, or carefully pry off old brick mold on window and remove all the celotex ?
SAGENT is offline   Reply With Quote
Old 05-14-2009, 01:15 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
sagent....on my house I would remove brick mold. Tape together and mark for re-installation. If you cut the celotex and butt sheathing up to it, its just another place for moisture and air to infiltrate.
12penny is offline   Reply With Quote
vinyl siding question DangerMouse Building & Construction 16 08-29-2008 06:20 AM
Vinyl siding question? kcrossley2 Building & Construction 5 12-18-2006 05:20 AM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
