Old 02-16-2011, 11:06 PM   #1
Another Rigid Insulation over Block Question
Hi. I just joined this forum and was hoping to find a quick answer to my questions. I searched and read thru about 12 pages of info on this topic but now I'm more confused than before. I have a 1955 house in Pennsylvania with a brick face over block exterior. I am remodeling room by room and see that the interior walls facing outside just have 3/4" furring strips attached to the block wall with 3/8" drywall attached to the strips. No insulation. I thought I'd add some 3/4" rigid insulation between the strips before screwing new drywall back into the wood strips. I did some research and decided to go with Dow Super Tuff-R since it has better R value than the other type (styrofoam or lowe's brand). i was just going to glue/caulk it to the block wall, maybe spray some Great Stuff from the can into any cracks, maybe tape the joints then install drywall. Then I was wondering which side of the Dow board faces the drywall, there is a foil side and non foil. DOW reccomends a 1/2" air gap between board and drywall, also 1/2" drywall. Then I started reading hear about possible moisture issues. So do I skip any insulation and just put up new drywall to keep it simple? Or am I OK with the Super-Tuff or some other type of digid insulation? Thanks.
jdon88 is offline   Reply With Quote
Old 02-16-2011, 11:25 PM   #2
I forgot to add a few things...the house has central air and heated by gas forced air. Since DOW reccomends an air gap should I use 1/2" insulation and 1/4" gap? Should I use 1/2" drywall instead of the 3/8?
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 08:54 PM
Insulation question Lockeset Building & Construction 4 11-10-2010 06:16 PM
rigid insulation under an attic storage floor? merlanvp Building & Construction 5 07-30-2010 08:32 PM
Sheetrock And Insulation Question kn1564 Remodeling 4 04-23-2010 12:24 PM
Question about Insulation russstar Roofing/Siding 13 08-21-2009 11:10 AM
